SOURCE: Can't get airconditioner to work
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If wont work then there are some safety device that work or defective. Try counting the blink of your green light so that I can convert the error code.
SOURCE: carrier central airconditioning heat unit - breaker trips when cooling turned on
well mineswas a blowen compressor
SOURCE: Carrier A/C in RV won't run
check your breakers make sure when running unit this is the only thing on the breaker 15 to 20 amp be sure to keep a window cracked as well unit does freeze over so don't have all the way on cold
SOURCE: My carrier A/C turns off by itself but the light blinks
Switch OFF the circuit breaker of ac, after 5 seconds. Switched ON the circuit breaker. If this will appear again try to check the wiring connection of ac.
