I have an old White Westinghouse Dishwasher and there is a little round compartment with a piece that twists out in the dishwasher door. It looks like the place you put the rinse agent, but I have poured 3/4 of a bottle in there and the cup never fills up. Should I be using a tablet instead of a liquid form of rinse aid?
Thanks,
victoria
SOURCE: westinghouse 906 leaks from front door
I’ve got the same make and model which had the same problem …if your sure its leaking from the door it will be coming through where the door jam or seal mounts and then leaking into the wall…..what you need to do is get yourself a tube of industrial silicon sealant and bead some silicon along between the back of plastic door seal mounts and the stainless steel wall lining...then allow silicon to set for 24 hours before running machine again
I believe over time the carcase and doors do warp causing these leaks
Hope this solves your problem
SOURCE: Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
SOURCE: water does not fill .
chances are, your water switch is stuck..
its the thing inside the dishwashe that kinda looks like a plastic mushroom.. (its a float)
sometimes they get corroded with excess detergent.. wiggle that up and down some to free up the float and it just might fix your problem.
SOURCE: dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
SOURCE: where to put Rince agent ?
there should be an oval shaped hole on the right, a small one, with out without a cap.... fill it with just a bit of rinse aid. it might or might not spill out but it will work..
