Question about Siemens SpeedStream Modem (4100) (SS4100)
DSL light flashing red - Siemens SpeedStream Modem (4100) (SS4100)
Posted by stavroutom on
Anonymous
    New Friend:
Why do my internet go off after i shut down my pc
Posted on Aug 10, 2010
frank thomas wilson
  • 10,319 Answers
Did you reset this modem by turning it off for a minute and trying it again? If no do so for it make work by this resetting mode
Posted on Jul 25, 2010
I recentley bought a dsl 2320b modem and now found out that it isn't supported with dlink anymore. There is no internet light on and the status light flashes very little. power light is red. dsl is steady...
Do you have an Internet service provider (ISP), like AT&T or Verizon (if you live in the US) ? Usually, your ISP will give you a modem/router (cable or DSL) for free when you sign up with them for Internet service.
Dec 20, 2014 | D-Link DSL-2320B
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
A problem has occurred when trying to access the internet. Please check your DSL/Cable connection and verify your internet connection settings. Wtf is this ? Firmware update doesnt helped. .
Cables connection might loosen up. Check cables that runs from the wall jack going into your modem, make sure all cables are tightly plugged in. Also, check indicator light on your device. If DSL light is RED, OFF, flashing red, flashing green. there might be trouble with your Internet provider. DSL light indicator MUST be always on STEADY GREEN. If you see that the DSL light is not on STEADY GREEN status call your Internet service provider.
Oct 27, 2012 | D-Link Dlink Dir-600 Wireless Router...
Hi I have a 2700hg-b modem router. the dsl light flashes green then turns solid red. I know it is fried, but the circuit board looks good. I am willing to pay shipping to recycle it. is there anyone that...
Hi...
The DSL light if it flashes in green, then it says it is trying to establish a connection with ISP...
Changes to red says "failed to establish the connection"...
The DSL light usually flashes green if there is a lot of noise in your telephone line...so it is also advised to do a line test for your connection...
--->> Recycling the Modem is a good thing, definitely you will be getting a good answer from some tech...
Dec 09, 2010 | 2wire 2700HG-B Router (2700HGB)
Hello
Does the DSL light come on at all when the modem is powered up?? If not, then it looks like the modem is bad.
When the modem is first powered on, all of the lights should come on and then go off after a few seconds. The power light should then begin to blink while the modem does a self test. Once that is done, the DSL light should come on and begin to flash red. If it senses a DSL connection, it will change to flash green until it has established a DSL connection. If it does not detect a DSL connection, it will continue to flash red. If the light does not flash at all or if the power light continues to flash after a minute or so, then the modem is most likely bad.
Let me know if you need more help. :)
Jan 12, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
2WIRE 2701HG-B with flickering DSL light.
The DSL is out in your area or the phone line has been disconnected.
I would contact ATT&T to find out if thire is a service issue in your area
Aug 15, 2009 | 2wire Computers & Internet
Dsl light flashes red constantly
Whenever your dsl light on the 2wire modem turns red,it only means that there is a problem with the dsl connection to the modem. Here are some ways on how you can isolate the problem
1. check if your modem is properly connected to the phone jack by unplugging and replugging you phone cable
2. try to reboot the modem
3. if still getting the same lights, contact your ISP
Nov 13, 2008 | 2wire HomePortal 1000HW DSL Modem and...
2Wire-3700 dsl red light blinking after a thunderstorm
If you are att customer, you will be charged $60 only if there is problem inside your premises, otherwise they wont charge you.
Is there any phone connected with your DSL line? if so is it working? if its not working, contact customer support and tell them its not working
If the phone is working, you have to check the connections between the phone line to the modem. As the DSL light is blinking red, its the problem with line and not the modem.
Take care
Jun 07, 2008 | 2wire (1000-000057-000) Modem
"fail: Test ADSL Line Sync" per AT&T Tech Readout
hi,there are a lot of possibilities y ur dsl light wont stop flashing red, 1.could be hardware failure,2.defective lead light for dsl,3.or line issue on the network...i strongly recommend that you contact your isp or att provider so that test would be done by their tech support,...basically you have checkd all inside wirings n as you have said you even tested the nid already...have you tried changing the dsl cable or phone cable? have you tried using another modem? were you using a filter for your dsl? you have to consider also other emi/rfi or electronic interference....but most probably you might try upgrading your modem n see if your gonna get a steady dsl light...the ethernet plugs has no effect on the dsl light...its just the cable connection or line issue or defective modem...i hope this will help, pls feel free to ask if you need further astnce...
Nov 29, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
2701HG-B
Hi. I will not repeat the check the phone line and resetting comments as it's now redundant.
I always have a spare modem as a line tester.
I've seen several 2700HG-B 2wire modem/routers burn out and every single time it's the DSL signal or modem portion that is burnt out. Even if you have two or three phone line surge protectors these 2700s are prone to shorting out unless you have a direct signal splitter DSL setup.
Here are a few things you can try to confirm if the 2700 is no longer functional on the DSL signal light problem.
#1: Turn on (plug in) your 2700 without the phone line plugged in and wait. If the DSL starts flashing red then there is a hardware problem in the modem/router.
#2: Plug the phone line into the 2700 while the dsl light is flashing red. It might take about 3 seconds however it should start to flash green and let it flash for about (usually) three minutes. If it turns red then the 2700 is indeed damaged.
#3: If you can enter into your modem using the http://2wire... and check the connection status. The first two status lines should read attempting to connect and no connection.
Nov 01, 2007 | 2wire 2700HG-B Router (2700HGB)
Siemens SpeedStream Modem (4100) (SS4100) Logo
540 people viewed this question
Top Siemens Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Terry
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
