Uninstall the software for ur printer and try reinsalling the software and also check ur instruction manual to see if ur printer is compabile with the try windows u are using.
What is the operating system installed on your computer?
Note: The Lexmark Z645 printer only works on Windows operating system. Unfortunately there are no Lexmark Z645 printer drivers available for Macintosh operating system.
HELLO THERE: I do not have the disk but i do have several links here that you can get the download from i would suggest that if they offer you the full suite use it it gives you a lot more features to use with this printer ok just look at the links below I hope this is very helpful best regards Michael
LexmarkZ645Driver DownloadLexmarkZ645driver download. To download Z645driver read the instructions below. ... Home Lexmark Printer Z645. Download Lexmark Printer Driver. May be useful ...nodevice.com/driver/Z645/get65147.html - Cached
Lexmark Printer Driver DownloadLexmarkdriver download. On this page we place a list of Lexmark...Lexmark. Z645. Driver for Lexmark Z640 Series. Windows Vista x64 / Windows 7. Download ...www.nodevice.com/driver/company/Lexmark/Printer.html - Cached
LexmarkZ645Driver download - Soft-Go.ComLexmarkZ645driver download for your printer device ...LexmarkZ645 is intended to be used with following operating system(s): Windows 2000,Windows XP ...www.soft-go.com/download_driver/Lexmark-Z645_37.html - Cached
Lexmark Printers Drivers - Download Drivers Free - Page 4Lexmark Printers Drivers free downloads: lexmark x422 mfp pcl and ...LEXMARK Z640 Z645Z645 Z647 INKJET PRINTER V1.0.3.1 WINDOWS VISTA X64. Lexmark. Item Title ...www.lostmydrivers.com/printers-drivers/lexmark/page_4.html - Cached
i have the link to your driver. you can click on this link or paste it on your browser. due to the cookies attached with it, it may not startto downloan immediately, so click on the cookies bar above your active rowser window to enable download. http://downloads.lexmark.com/perl/downloads/downloads.cgi
cheers!
this is the site from lexmark that will provide you with any software or drivers that you may need. however for installation of the machine itself. here are a few tips.
have the drivers downloaded to a specific place in order to find it easily. (do this before connecting the device to your computer)
plug in the cables leading to your printer, and plug in the power cord. not the computer connection.
open the top of the printer to open the ink carrier. insert the ink cartrage.
connect the computer cord to the computer. (just insert if USB, however i would suggest to shut down your system if it uses parrellell cable.)
install the drivers you downloaded by clicking it. go through the installation and your printer should be ready.
Note* when you connect a new device most times your computer will want to automaticly find new drivers. most software instructs to cancel that.
Here is the driver download page. Select your operative system and download the driver software. After downloading do the following:
1 disconnect printer from computer. 2 go to installed printer on Windows and eventually remove installed printer Z645 with bad driver, if there is one (suggested). 3 open the driver that you downloaded from link above by clicking on the downloaded file. 4 while program install click next when required, connect the printer only when explicitly required by software.
You need to download the driver software ( same you got in the disk ) from Lexmark website. Download software into the computer where you are going to install the printer. It is important that you do not connect the printer before installing software. Install the software downloaded and connect printer only when explicitly required by software setup program. Here is the driver download page , select your windows version and start download.
If this is a newer printer that can use a USB cable, then you want to boot up the laptop, If you arte running XP or Vista, make sure you have admin rights. Install software with the printer disconnected from computer. Once install is either completed or asks for printer connection, power on printer, wait a few moments, then attach the USB cable top a poert on laptop. Install should continue, and you should be good to go.
