Question about Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony Wega tv
Hi, I had a Sony Wega tv. This afternoon, when I wanted to turn on the tv, it wouldn't turn on. Instead, the indicating light near the "power" button just keep blinking.
Posted by shengfwang on
Anonymous
  • 129 Answers
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Posted on Jul 26, 2010
Hello, my sony wega 42"
Dear , i think its Physical Problem in your TV, if your projection Lamp is Ok , so then its a Picture Tube or may be its a Display Circuit Problem..
Jul 24, 2011 | Sony Televison & Video
What does standby mean? my tv will not come on but the red standby light is on. How can i fix my tv.My tv is an sony 40" trinitron wega brand.
If standby red light is solid then press power or channel button on remote of tv itself to turn it ON.
And if red light is blinking/ flashing then it is an indication that tv got problem and tech visit is needed to sort out problem.
Thanks.
Apr 20, 2011 | Sony Televison & Video
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
I have a Sony Wega KV-34HS420 TV that takes several tries to turn on. When I push the power button or remote power on I hear the normal click and the sound comes on for 3-5 seconds but then I hear a second...
Since the set appears to "recover", it suggests either a poor solder connection or bad cap somewhere in the power supply. The 7 blinks indicate the problem circuit is in the horizontal area. Check the regulator (STRxxxx) IC in the power supply. If you do not have experience working with TVs, please refer this repair to a shop. The regulator IC costs around $25.
Dan
Nov 16, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have 4 32" Sony triton TV's that turn on and off
I think problem in power supply section and it would be nice if you could provide exact model number of your Sony TVs, question headings show it is KV-32FS120 TV, please confirm to proceed further.
Thanks.
Sep 18, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a sony grand wega model kf-42we610 I will be watching tv and it will turn off on it's own and then come back on 30-60 seconds later. If I turn it off the light under the power button will blink 5...
Check your lamp cover on the rear it may be loose which will cause the tv to turn off. Also the light under the power light is the lamp indicator. If it is blinking it may be getting ready to fail.
Jan 29, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
