Question about Seagate Free Agent Go Small 12 GB USB External HD ST600121GSA1E1-RK USB 2.0 Hard Drive
When i power on my pc then it display intel with blue black screen,after than black screen display with two line,-bootdevice not detected and in second line indicates that refers net support products like http://support.intel.com/support/motherboards/desktop
Posted by mouryakailas on
1 Related Answer
dgsturt
  • 1705 Answers
SOURCE: boot device not detect
Your PC is trying to boot from your external hard/flash drive.
You have to change the boot order in the bios. While booting what the screen, you'll see a message "Select F2 for boot or DEL/F10 for setup"
Go for the setup option, this will take you into the bios. Read the instructions carefully, you need to change to boot order, choose CD for 1, HDD0 for 2 anything you like for third. Press F10 to save and exit. Your
PC should now boot properly.
Or, as its just a flash drive, don't plug it in until your PC has booted.
Posted on Jul 24, 2010
When i am try to install windows my pc geting hang or stuk & in some time it was give me a blue scree error i am try to change my all parts except D865GVHZ board if any solution is there in your hand...
  • you have to install OS by a Bootable CD, Insert the CD and restart your PC
  • you pc will detect the CD press any key to continue ( remember select you CD ROM drive as first boot device)
  • then as usual follow the instruction
Feb 15, 2011 | Intel D865GVHZ Motherboard
Laptop scree has a blue veritical line to the left side of the screen.
your screen is either about to fail or was severely pressed against a hard surface. unfortunately in most cases you just have to change it if the lines become too many. but in the mean time you just have to soldier on
Nov 09, 2010 | Computers & Internet
Black screen with blinking cursor in left corner.
Please power off, remove the RAM and then reinsert the RAM. Power on the pc.
Aug 01, 2010 | Intel D945GCCR Motherboard
Boot device not detect
Jul 24, 2010 | Seagate Free Agent Go Small 12 GB USB...
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
BLUE SCREEN; AutoFocus " UNMOUTABLE_BOOT_VOLUME "
Unmountable boot volume is an error you get when your hard drive is failing. You will need to replace the hard drive.
May 21, 2009 | Toshiba Satellite L35-S2366 Notebook
Blue scree, or system crash
This link should help you a lot. The problem is an unmountable boot volume.
http://www.techtips4u.com/kb/sw/SW00014.htm
Please let me know if this helps you out.
Mar 12, 2009 | Dell Latitude D600 Notebook
Seagate Free Agent Go Small 12 GB USB External HD ST600121GSA1E1-RK USB 2.0 Hard Drive Logo
Top Seagate Computers & Internet Experts
Michael Thomas
Michael Thomas
ChinthakaJ
ChinthakaJ
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
