Question about Stanley Fatmax Xtreme Retractable Utility Knife
How do you remove the blade from the stanley utility knife? 10 7088
Posted by sduros92 on
5 Related Answers
mark24354
Mark T
  • 776 Answers
SOURCE: WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Posted on Nov 20, 2009
Anonymous
SOURCE: Just purchased a Stanley FatMax 10-778 retractable
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Posted on Apr 11, 2010
Testimonial: "Thanks so much!"
ADRIAN
  • 313 Answers
SOURCE: How do you load a new blade?
At the back end of the knive (the curved end) press the black piece through the yellow rounded part and the yellow front and the black back will part, now slide the yellow part back to reviel the blade folder. Fit new blade then refit the yellow part on top of the black part and slide the yellow part foward to lock it back in.
Posted on Jul 31, 2010
puertobori
  • 7733 Answers
SOURCE: Just purchased a Stanley fatMax
Some models has 2 screws on the knife case.unscrew them and you can access to the blade.
Posted on Nov 08, 2010
GadgetKing
John King
  • 40 Answers
SOURCE: can i buy a new blade slide for extreme utility
I can't see what country you live in from your profile, but if it's the UK, you could try www.partmaster.co.uk . They sell parts for just about anything.
Posted on Feb 28, 2011
I have a stanley fatmax knife but it doesn't have the small yellow button to help insert a new blade. what can I do?
HI!Kindly pull the button on the end of the knife and then after you remove that you can now put the blade of your knife.
Aug 21, 2011 | Stanley Utility Knife
Have a Stanley Fat MAx utility knife and unable to open it to load the blade
there is a little black button on the end where the blade comes out. With the blade in the out position,push in the button and pull out the blade. With button pushed insert new blade or turn the old one around to use the other end.let go of the button and you are ready to go.
Jun 26, 2011 | Stanley Utility Knife
I cannot figure out how to put a blade in my Stanley FatMax fixed blade utility knife. There are no instructions with the knife.
at the handel end it will pull apartthen slide the whats left of the old blade and put new won in its place just do it slowly so you dont forget how it goes
Apr 21, 2011 | Stanley Utility Knife
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Stanley 10-801 utility knife. How do you change the replaceble blade?
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
Nov 26, 2010 | Stanley Garden
I unscrewed Stanley 10-379 Interlock retractable knife and now I don't know how to put back the gizmo that fell out or the three blades that came with it.
Google: how to change blade in Stanley 10-379 utility knife. Stanley website shows how knife & blade look on the outside. Put it together so it looks like that. Sorry, but ain't don't know how to send the picture to you.
Oct 21, 2010 | Garden
How do i change the blade in a stanley fatmax?
You do not have to remove any screws. Extend the blade outward using the thumb slide on top of the knife. There is a small black pushbutton on the opposite side from the lock button. Depress the button on the side and using the other hand, grab the blade with your thumb and forefinger to pull the blade out. It may require a little wiggling. Now the new blade can be slide in and locked into place. The black pushbutton controls the locking mechanism that keeps the blade from pulling out.
Aug 07, 2010 | Stanley Utility Knife
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
Sorry.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
Stanley Fatmax Xtreme Retractable Utility Knife Logo
88 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
