Microwave Ovens Logo
Posted on Sep 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fire inside microwave, Closed the door after using defrost. There was a funny smell & a glow coming out of the unit. The plate shattered & the plastic wheel melted. I opened the door & everything stopped. I closed the door & it went back to starting a fire. The only way of shutting the unit off is to pull the plug. Am I looking at an un-repairable unit?
Bill Boyd
Level 3:
Top Expert:
  • Maytag Master 53,816 Answers
  • Posted on Sep 04, 2017
Bill Boyd
Maytag Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925773
Points
172802
Unrepairable unit
junk it
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 15, 2006
SOURCE: Door latches to microwave broken
I assume you're talking about the spring that keeps tension on the door hooks (latch heads, as they're called by Sharp). When you shut the door, the "hooks" are held down by this spring to actuate the door switches. To fix this, you'll have to separate the door panels. You can download the service manual from my Web site. There's a loop built into the latch head assembly and sometimes the loop breaks. If so, you can drill a tiny hold in it and reattach the spring there. There may also be a loop on the innner door panel to hold the spring. That one can break, too. If it's broken, you'll have to find a way to secure the spring to the panel. If the panel material is thick enough, a tiny screw eye could be inserted, then epoxied overnight to secure it. I've attached a diagram to this message that should help you. If that doesn't help you, I have the service manual for the R1600-series microwaves on my Web site at: http://www.microwavedisplay.com/R1610.pdf Repost if you need more help.
Anonymous
  • 833 Answers
  • Posted on Dec 19, 2007
SOURCE: E-wave KOT-152UB glass tray and turning ring melted
Sounds like some metal is involved somehow. If the unit otherwise works, replace the damaged parts. Test with a cup filled with water.
Anonymous
  • 226 Answers
  • Posted on Jan 27, 2008
SOURCE: Dead Microwave
Remove the top cover of oven, there should be tec screws on the bottem of unit to remove the cover, check for bad relays,fuses and fuseable links that could have finaly gone bad.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Apr 18, 2008
SOURCE: Microwave oven runs with door open
This is usually caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
Anonymous
  • 108 Answers
  • Posted on Nov 16, 2008
SOURCE: GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Rag burnt, is it safe to use the micro? The rag burnt badly, there was smoke and a strong bad smell persists. Is it safe to keep on using the micro, what can be done about the smell?
Hello -
It is probably safe to use the microwave oven after removing the burned smell.
I found some methods for removing a burned smell from a microwave.
https://blog.bostonappliance.net/5-foolproof-ways-to-get-burnt-popcorn-smell-out-of-the-microwave/
(Quote)
1. Fill a bowl with 1/2 cup water and 1 tablespoon white vinegar.
  • Microwave it for 4-5 minutes and leave it with the door shut for 10-15 minutes.
  • Steam will loosen smell-causing detritus stuck to the walls. Vinegar absorbs odors, even stubborn ones like burnt popcorn smell.
  • After the waiting period, remove the bowl and wipe the inside of the microwave down with a paper towel
2. Not good enough? Okay - soak a sponge with vinegar.Place some baking soda on top and microwave the sponge for 25 seconds.
  • Wipe the inside of the microwave with the sponge.
  • Don't forget the glass tray and the microwave door.
3. If steps 1-2 don't remove all the grime, soak cotton balls with acetone-free nail polish remover and wipe down the inside of the microwave.
  • Even stubborn stains should come out.
  • Wipe down the inside with soap, then vinegar water, to remove the polish remover.
  • We recommend following through with step 4 to get rid of chemical smells.
4. Banish the remaining smells with the power of citrus.
  • Peel two oranges or slice a lemon in half.
  • Place the orange peels or lemon slices in a bowl of water (1-2 cups).
  • Microwave it for 4 minutes. Watch closely to ensure that the water stays in the bowl and the citrus peels do not burn.
  • If possible, leave the bowl in the microwave (with the door closed) for 12 hours.
  • Too time-consuming, or just not doable for you? That's okay too. Let the bowl sit in the closed microwave for half an hour then, if the burnt smell persists, continue to step 5.
5. Still bad odors in your microwave? Leave an open box of baking soda on your microwave tray overnight.
  • It will neurtalize the odor without adding to the smelly situation in any way.
  • You can also place coffee grounds from your morning coffee in a bowl in the microwave all day while you are at work.
  • If you don't mind coffee smell, you can microwave 2 tablespoons of coffee grounds in a half cup of water for 2-3 minutes to expedite the process.
(End quote)
Best wishes.
Why did the glass in microwave door shatter melt?
A spoon in the coffee the cup had metal parts
When I open microwave oven door . close the door again light comes on an plate spins an wont stop unless I unplug it
Inside the door latch, is a safety feature, that prevents the microwave from operating unless the door is closed. This feature can easily become faulty, or even come with the fault already causing the microwave to constantly operate whenever the door is closed.
Microwaves can be very dangerous in regard to holding HEAPS of voltage within the unit. I recommend getting yourself a new microwave, as attempting repairs on any of the modern units can, more often than not, be far more costly then the price of a new one.
Hope this helps.
1helpful
Stopped cooking
This is technical!!! Don't know how handy you are but the biggest reason for microwave failure is a diode (HV) between ground and the lead to the magnatron. usually mounted low down low on the right inside of the unit. Also, there are about three microswitches in the door closing latches to make sure the door is properly closed. Sometimes they come loose or fracture the mount. then of course there is the Magnatron its self. I save them from old units. They are different wattages but physically the same and simple to change. Good luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Wire burning smell from Microware
unplug it.....if on fire, use dry chen extinguisher, if still persistent, dial 911 n get out of the house
1helpful
2answers
The inner door glass shattered and now no power
There's a safty switch which prevents the unit from operating if the door isn't fully closed. When the glass shattered a small piece may have blocked the switch from operating properly. Check around the door seals for any irregularities.
Heating element comes on to high by it's self when no buttons have been touched. I had just finished cooking a cassorole. I closed the door and sat down to eat,when after 5 minutes had passed the exhaust...
I am sorry but the relay that controls the heating element has become faulty, if you or someone you know can change it then just follow the heater lead to the relay and replace
Russell Hobbs HOB CTS34 - Faulty glass plate
Door glass broken on russel hobbs 28lt micro wave. Any idea where I can have this replaced. thank you
Microwave door shattered
Give is the entire model # on the sticker inside the microwave and I should be able to help.
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
