http://windowshelp.microsoft.com/Windows/en-US/help/bfd3bd31-82f0-4b9c-9cde-fb92bc2b14771033.mspx
Enabling ICS
To enable ICS, on your host computer:
1. Open Network Connections by clicking the Start button , clicking Control Panel, clicking Network and Internet, clicking Network and Sharing Center, and then clicking Manage network connections.
2. Right-click the connection that you want to share, and then click Properties. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
NoteThe Sharing tab will not be available if you have only one network connection.
4. If desired, you can also select the Allow other network users to control or disable the shared Internet connection check box.
5. Optionally, to allow other network users to use services running on your network, click Settings and select the services you want to allow.
When you enable ICS, your local area network (LAN) connection gets a new static IP address and configuration, so you'll need to reestablish any TCP/IP connections between your host computer and the other network computers.
To test your network and Internet connection, see if you can share files between computers and make sure each computer can reach a website.
Once you have done the above, connect the Ethernet cord to the WAN/Modem port on the Linksys router and set the router to Dynamic IP. Then connect another computer to one of the LAN numbered ports on the router and they will have internet. Remember your computer MUST be on for the computers connected to the Linksys to get internet.
