Hi the signal problem may be cause be a bad antenna and you need to tell what kind of radio device is it? so i can get the solution for you.
It's a Uniden BC92XLT - the Antenna's fine as I've already got a hold of a spare and tried it...it makes no difference.
I strongly suspect it's something to do with the software/hardware inside the unit itself, whenever the scanner no longer picks up radio chatter the scanner at the same time takes ages to then also scan through all the frequencies, but all the time it is able to pick up radio chatter it'll scan through all the frequencies in an instant...that's what makes me suspect it's software/hardware related, but I think I'm safe in saying that the Antenna isn't what's at fault here
Hi there, you need to program it you can follow these steps to program your BC92XLTPress 1 then Press Hold (You are now on Channel 1)
Press Func then press E
Enter Frequency
Press E
Press Hold two times (You are now on the next channel)
Repeat Steps 2 through 5
Please let me know if it work.
Do you have this problem with all Frequencies or are you scanning public safety, Fire and Police, Frequencies? If the issue is on public safety frequencies it's not your scanner. They have started encrypting their control frequencies to keep people off of them and some areas are upgrading to trunked systems which the older scanners can't track. There are scanners that can but I don't believe yours is one of them. If it's all frequencies your having trouble with my guess is you've got an antenna problem.
(I do not believe the Antenna is at fault, possibly the software?)
