Question about GE Profile PGSS5PJXSS Stainless Steel Bottom Freezer French Door Refrigerator
Items in refrig are freezing when they're not supposed to.
All produce, fruit and anything with liquid in it is freezing in the back half of the refrigerator and the crisper drawers.GE Profile PGSS5PJX french door, freezer on the bottom. Refrig and freezer are set on the correct temp. Moisture controls in the refrig (crispers) are set to low as was suggested by others. Refrig is 2 yrs. old everything else is working fine. Very hot and humid here.
    New Friend:
We have the exact same issue with our refrigerator .... its maddening. It appears to be related to loading in the refrigerator and covering the vents that feed cold air from the freezer compartment into the refrig. We a very careful about where we place things and run the refrig at higher than nominal to avoid the problem as much as possible.
Posted on May 20, 2015
    New Friend:
  • 112 Answers
Thermostat has failed i'd say..its not turning off at the requested temp.
Posted on Jul 24, 2010
6ya staff
SOURCE:
How to freeze apricots
Before freezing, be sure you clean them thoroughly and avoid using any apricots that are damaged. Once apricots are washed and patted dry, cut them in half and remove the pits. Then slice them as you would slice peaches or any other similar fruit.
Boil a medium sized pot of water and dip the slices for about 30 seconds to prevent the skins from toughening, then place in strainer and run under cold water. From this point, freezing them may be done a few different ways, but the most important part is to be sure to include ascorbic acid to keep the apricots from turning brown.
One of the more common ways is to freeze them in a syrup. To make a simple syrup just add one cup of water with one cup of sugar to a pot. Heat and stir until all sugar dissolves. You will need about a half cup of syrup for each pint container you plan to fill with apricots. Then, add 1/8 teaspoon of the ascorbic acid to every cup of syrup.
Pour half of your syrup into a pint sized container you intend to freeze, then layer the apricot slices into the container, leaving about half an inch of space at the top, as the liquid will expand during the freezing process. After that, close the container, label it if preferred, and freeze it!
With this process, frozen apricots should keep for about 18 months if left in the freezer. Best of luck!
Jun 05, 2014 | Camping, Backpacking & Hiking
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Is there a large selection of freeze-dried foods?
Huge! You can find almost anything you want that has been freeze-dried, you just have to know where to look. Many companies now carry not only the basics (fruits, vegetables, protein); they have become very creative and learned to freeze-dry items like milk, full gourmet meals and even ice cream.
Jul 31, 2012 | Camping, Backpacking & Hiking
Refrigerator is freezing my produce items (veggies&fruits) Freezer side is thawing and ice is melting waterfalls over and down all other levels. Freezer & frig. settings have always been set on...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 10, 2010 | Kenmore 25.1 cu. ft. Side-By-Side...
My refrig is freezing items on the refrig side.
likely a bad temperature control. also, some model GE's have a bad fresh food inlet cover, that fails to cutoff airflow from the freezer.
Feb 19, 2010 | Refrigerators
Items in the back of the refrigerator freeze.
is this something that has just started happening? Most kenmore top freezers have a vent that allows cold air from the freezer into the refrig through a vent located on the back wall in the center of the refrig section. if packages are pushed up under this vent they can freeze.
If you have widespread freezing in the refrig setion then a temperature control could be the fault. thanks for using fixya. Peyton..
Feb 17, 2009 | Kenmore 72992 / 72994 / 72999 Top Freezer...
Dorm refrigator icing up
Make sure the fridge and freezer are not packed with food. It needs a lot of breething room.Also make sure the door is seeling tight. Not a lot of room in small fridge. Good luck
Sep 06, 2008 | Frigidaire Refrigerators
Freezing in refrig and freezer.
call the tech back... the control board may be fauilty or install incorrectly.. the water leak is from a pluged drain hose or your ice maker leaking not from a control board...
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Sub-Zero 550 water leak and freezing
Seems to be a common problem with these units. You can get a drain tube heater ( got mine from an online refrigerator parts distributor), though may not totally solve problem. Some suggest running a copper wire through tube - supposed to conduct just enough heat to keep tube from freezing.
Sep 05, 2007 | Sub-Zero 650 / O Bottom Freezer...
GE Profile PGSS5PJXSS Stainless Steel Bottom Freezer French Door Refrigerator Logo
632 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
Vish Iyer
Vish Iyer
