The Learning Company Zoombinis Logical Journey (480593) for Mac, PC Logo
Posted on Jul 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can some1 please tell me how I install quicktime 2.1 for windows please as im having trouble installing Zoombinis Maths Jouney?
Anonymous
Level 3:
  • Master 487 Answers
  • Posted on Jul 24, 2010
Anonymous
Master
Level 3:
Answers
487
Questions
0
Helped
105295
Points
1340
Hi, try this link: http://www.oldversion.com/QuickTime.html
Hope this helps
7helpful
How can install zoombinis on window 7
You should navigate to the setup file on the disc, right click, select 'Properties', choose the 'Compatibility' tab, select the 'Run in compatibility mode for:' checkbox, select 'Windows 98/Windows ME'. Then run the setup program.
Alternatively, you could right click on the setup file and choose the 'Troubleshoot Compatibility' option.
The problem here is that you likely have Windows 7 x64 which has little support for 16 bit programs. You may be able to run your program in Windows Virtual PC (XP mode) if you installed it, but the program will likely run rather slowly.
If the solutions I have provided do not work, then I hate to say this, but you are out of luck.
When I try installing Itunes half way through installing a pop up comes up saying- "Could not access network location %APPDATA%\." Can u help me fix this.
Please take note that the following steps is in assumption that you are using a Windows operating system.) As I have found out in the iTunes support in apple.com, this symptom may be caused by anti-spyware software preventing iTunes from installing correctly. One such application is SpyCatcher. Before installing iTunes, temporarily remove this software to allow the iTunes installer to complete.
If you are still having trouble installing iTunes for Windows, follow the troubleshooting suggestions described in this article.
General installation troubleshooting Important: iTunes installation is successful a majority of the time after completing these troubleshooting procedures. If one step does not resolve your issue proceed to the next.
1. Empty your Temp directory and restart
Windows XP:
  1. Choose Start > My Computer (or double-click My Computer on the Desktop).
  2. In My Computer or Computer, open the "C:" drive.
  3. Open Documents and Settings.
  4. Double-click the folder titled with your username.
  5. If you see a Local Settings folder, skip to step 10. If you don't see a Local Settings folder, proceed to the next step.
  6. Choose Tools > Folder Options.
  7. Click the View tab.
  8. Select the option to "Show hidden files and folders."
  9. Click OK.
  10. Double-click Local Settings.
  11. Right-click on the Temp folder and choose Delete.
  12. In the confirmation dialog that appears click Yes.
  13. If you are unable to delete the Temp folder, close all programs, especially those in the Notification area ("System Tray") of the Windows Task bar and repeat step 11.
  14. Restart your computer.
Windows Vista and Windows 7:
  1. Choose Start > Computer
  2. In Computer, open the "C:" drive.
  3. Open the Users folder.
  5. If you see an AppData folder, skip to step 10. If you don't see an AppData folder, proceed to the next step.
  6. Choose Organize > Folder and Search Options.
  8. Select the option to "Show hidden files and folders." (In Windows 7 this option will be called "Show hidden files, folders, and drives").
  9. Click OK.
  10. Double-click the AppData folder to open it. If Windows needs your permission to continue click Continue.
  11. Double-click the Local folder to open it.
  12. Right-click on the Temp folder and choose Delete.
  13. In the confirmation dialog that appears click Yes.
  14. If you are unable to delete the Temp folder, close all programs, especially those in the Notification area ("System Tray") of the Windows Task bar and repeat step 12.
  15. Restart your computer.
2. Completely remove iTunes and QuickTime
For Windows XP, follow instructions in Remove and Reinstall iTunes, QuickTime, and other software components for Windows XP.
For Windows Vista or Windows 7, follow instructions in Remove and Reinstall iTunes, QuickTime, and other software components for Windows Vista.
Note: Songs you purchased from the iTunes Store or imported from CDs are saved in your My Music folder by default and are not deleted by removing iTunes.
3. Install the latest version of iTunes
Once you have completed the above steps to Empty your Temp directory, Completely remove iTunes and QuickTime, and Clean up iTunes installer files on the computer, you can install the latest version of iTunes from http://www.apple.com/itunes/download.
Additional troubleshooting Make sure you have administrator-account access To install iTunes or QuickTime software, you need to be logged in as an administrator on the computer. If you're not sure if you have administrator-account access, contact the owner of the computer or your system administrator.
Get the latest Windows updates The first thing to do when troubleshooting an installation issue on a Windows computer is make sure you have the latest Microsoft Windows updates installed—to get the latest updates, go to the Microsoft Windows Update page.
iTunes and QuickTime software for Windows require Microsoft Windows XP or Microsoft Windows Vista with latest Service Pack installed.
Disable other conflicting software In Windows, some background processes can cause issues for other programs and processes. These conflicts can prevent applications such as iTunes and QuickTime Player from installing. See Using MSCONFIG to troubleshoot conflicts in Windows XP or Using MSCONFIG to troubleshoot conflicts in Windows Vista and Windows 7 for assistance disabling conflicting processes.
Additionally, some third-party security software cannot be disabled using Selective Startup (MSConfig). Because of this, it may be necessary to temporarily manually disable such software while troubleshooting installation. For assistance in configuring or disabling your security software, please contact the manufacturer.
Make sure your folder names don't contain strange characters If the iTunes installer (iTunesSetup) is not responding or appears frozen after launching the installer then the folder where the installer is stored may contain unusual characters. If you notice that the iTunes installer or stored in a folder like this, either rename the folder or move the iTunes installer to another location such as the Desktop before launching.
More help If these steps don't help, you may be able to find a solution to your issue by searching the Microsoft support website.
If the above troubleshooting steps have not helped, proceed to the following steps Solutions to common installation errors Here are some common symptoms you may see when installing iTunes and QuickTime for Microsoft Windows. If you are experiencing one of these symptoms, try the suggested troubleshooting steps:
If you only need to install QuickTime, or if iTunes installs but QuickTime installation did not complete Try downloading and installing the standalone version of QuickTime from http://www.apple.com/quicktime/download/. Be sure you download the version that does not include iTunes.
When im starting the game, it says unable to initialize graphics. what do i have to do ?
it means your game does not support your current graphic card, you have to install a additional graphic card, go to the your nearest computer shop tell about your game they will suggest you which graphic card is suitable for your game.
2helpful
It keeps asking for quicktime 2.1 but we already have version 7 or later
If software is older version, some producer have limited life time with version of other applications required. Try downloading required version of QuickTime.
3helpful
3answers
I recently upgraded windows vista to windows 7. i did this for the sole purpose of getting my zoombinis logical journey to work and run. it will not start and i need to know if there's anthing i can do to...
well, i thought that windows 7 would have been developed to be compatible with ALL of the previous systems and programs that they were compatible with. as it is, windows 7 DOES have a way in the control panel that helped me out... there's actually a link in the control panel called "run programs made for previous versions of windows" it took a few tries to get the right setup for the game, but it's pretty self explanatory. sometimes it takes a couple of tries to start it up, but now i CAN play Zoombinis on my windows 7 pc.
6helpful
3answers
Zoombini's Logical Journey won't start up
If the program produces an error right after hitting the Play button, I had success by launching the file Zoombinis Logical Journey.exe in compatability mode using Window 98 / ME and 640 x 480 resolution. The shortcut that is created during install points to TLCRUN.EXE which was what caused my error.
Top The Learning Company Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
