Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
Posted on Jul 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No hot water
I have a rheem tankless water heater PTG-53PVN the temp. control is blinking it displays C4 alternating with 76
Lickzee
Level 2:
  • Expert 68 Answers
  • Posted on Jul 31, 2010
Lickzee
Expert
Level 2:
Answers
68
Questions
0
Helped
31470
Points
129
Contact rheem you probably have a circuit board problemb
Ptg 74pvn 2 rtg 74pvp
copy following links for rheem/eco-sense error codes, manuals, required yearly maintenance, support number and resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Probably bad PC board, or bad remote control
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Error code C4 76
Error 76 is communication fault with remote control, or bad PCB board.
Copy following link for Rheem tankless troubleshoot:
Call Rheem, and they will recommend service technician.
800-432-8373
Make sure your unit is serviced yearly to prevent common error codes. Which defeats the robust $100 expected yearly savings from owning a tankless water heater.
I have a poloma model/ pt62-42pvn its flashing error code c4 76 i have had no hot water for six days now need help
1) Before calling service technician who can test parts, open following link for Rheem resources including error codes, Rheem chat and phone number, possible manual:
If local technician cannot solve problem, Rheem can probably recommend a person.
2) Error codes are start-point for troubleshooting.
3) Multiple error codes can indicate PC board failure.
If your computer motherboard fails, most people feel the computer is compromised even after motherboard replacement.
4) Error code C7-76 is communication error with remote, and can include bad remote, bad wire to remote, loose wire, or bad PC board.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
5) Error C4-13 can include part failure, vent problem, oxygen depletion, and can also include PC board failure.
http://waterheatertimer.org/pdf/Error-code-13.pdf
6) Tankless routine maintenance manual:
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
7) Some posts about tankless concede that qualified technician was unable to repair unit.
Solve most tankless problems yourself, same day, for about $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
2helpful
2answers
Have a Rheem PTG-74PVP tankless water heater. Shuts off after a few minutes while taking a shower. Get a code 76 C8
Before calling service technician, open following links for troubleshoot resources including error codes and rheem chat, and typical scheduled maintenance:
Error 76 can mean communication failure between tankless and remote control, which can include bad remote control, bad wire, bad wiring connector, or PC board failure.
Disconnect remote control and see if tankless will work.
Error C8 76 can mean PC board failure.
Contact Rheem and/or service technician.
1helpful
Thermostat flashes IL ? Model PTG-53PVN
http://www.palomatankless.com/owners/homeowner+trouble.lasso#28-11
The Controller displays error code "1L."
There is a build-up of lime in your Paloma.
Contact your plumber to service the Paloma by flushing out the lime.
Also search u-tube for flushing lime out of tankless.
My tankless indoor water heater has an error code C4 76
Error code 76 indicates a communication error with the electronic board and the unit. Call Paloma/Rheem with the serial number and model number of your unit and they will, in most cases, send you a new board with instructions on how to easily replace the board.
Tech Support: 800-432-8373.
Error codes c4 76
contact rheem it sound like the circuit board is gone
5helpful
3answers
Error code 76 C4 heater shuts off every 5 mins while in shower
Remove power source from the unit. If remote control2.gif is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support2.gif.
If this helps, please indicate so.
Mike//
[email protected]
Rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
