Good day,
There are several component we need to consider in order for us to give you a more appropriate solution to your dilemma.
1. There are pin configuration at the back of your hard drive which can be switched from one combination to another. These pins is for boot sequencing. Try switching your hard drive pin configuration from master or slave to auto detect or IDE detect.
2. IDE cable must be inserted correctly. IDE cables have red lining on one side which indicates the proper insertion. Red Lining must be facing the red wire from the power supply cord. Try looking a closer look.
However, we need to ask you a few questions to give you a more direct answer.
Kindly provide the following.
1. Is you hard drive an IDE type it SATA.
2. Motherboard specs.
3. Memory allotted.
Should you have any questions, feel free to approach us.
