Question about Canon iR 2016i Black and White Copier
Canon copier ir 2016 giving error msg E 246 ,how can i solve the problem?
Posted by ahmadmenye on
Canon tech CROATIA
  • 1,219 Answers
Hi, these error code isnt in service manual.The Canon says that you need to report these problem to your authorized dealer.
Posted on Jul 24, 2010
What is the error code 246
Error code 246 does not seem to be a defined error code from Canon. However if you go to page 13-176 in the service manual at this site and run the error log report, it should give you some indication of what actual error codes are occurring at that time. This should help narrow down the cause. All the possible error codes for both copier and fax are listed in these pages.
http://iiruc.info/gol/CopierPrinterFaxSM/Canon/ir1600_1610-sm.pdf
Sep 01, 2014 | Canon iR 1600 Copier
How to solve E-540 error in canon ir 2016
You need to ask about this in the canon service centre. Please also mention what errror your camera is showing.
May 26, 2012 | Canon ImageRunner 2016 Copier
Canon iR-2016 System erro E007
The fusing unit needs to be replaced or repaired. Contact your dealer or service person
Nov 20, 2011 | Canon CLC 1140 Copier
Hoo.comi want to solve the problem in my copier canon ir 2016, error code e354
this is error code that isn't stated in service manual and doesn't have description. When this error occures the procedure is to report to Canon service center. The same errors were on ir1600/2000 series, but without some good explanations.
So, call authorised CANON service partner!
Sep 13, 2011 | Canon iR 2016i Black and White Copier
It shows code 246 canon ir 2016
I think this is a strange error code. Let me help youWhat is the last activity that you carried out on the machine ? Did you try reseting the machine in service mode? If not do the following Press Additional function,2,8,Additional function Use < or > keys to scroll & select CLEAR. Press OK Use < or > keys to scroll & select ALL. Press OK. Now switch off the machine & switch on. Did this solve your problem.
Apr 18, 2011 | Canon iR 2016i Black and White Copier
I have Canon iR 2016 it show E808 code error
i have canon Ir2016 it give 808 error code can u help me please
May 29, 2010 | Canon iR 2016i Black and White Copier
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Apr 18, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
hi how do solve this problem system error E007
Dec 04, 2007 | Canon CLC 1140 Copier
Troubleshooting, Error Codes for canon ir 2016.
I have problam Canon IR 2016 error message SYSTEM ERROR E 007
Oct 01, 2007 | Canon ImageRunner 2016 Copier
Canon iR 2016i Black and White Copier Logo
483 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
