The AC manifold gauges set have the three chambers: the low pressure chamber (left side), utility chamber (middle), and the high pressure chamber (right side).
When technicians connect the HVAC manifold gauge to the air conditioner units, he connects the low pressure side of air conditioner unit to low pressure gauge side.
If he wants to read the pressure in discharge line he connects the high pressure gauge hose to the air conditioner high pressure side.
The utility port (the middle chamber) is a place you connect the hose to vacuum pump, recovery units or add or remove refrigerant from AC units.
Air conditioning gauges is used to measure air conditioner units pressure within closed-system to evaluate or troubleshoot the AC units. Gauges manifold set is the most frequently used item when it comes to refrigerant or pressure.
Air conditioning gauge set allows the HVAC technician to check AC units operating pressures, transfer AC refrigerant, pressure test system, purge the system with nitrogen, and perform other necessary tasks.
The gauges manifold set includes the hoses, the manifold, the valves, the compound gauge (low pressure gauges) and high pressure gauge.
low pressure is suction or liquid and do ihave to turn the unit off to hook up gauges or check the pressures
Yes you will have to do it. To check the pressure you dont have to.
which hose hooks to which line
The blue hose will hook up to the suction line port, whice is the bigger pipe with insulation. The red hose will hook up to the liquid line, which is the smaller pipe without insulation. The unit can either be on or off to hook up gauges, just make sure you use low loss fittings on your gauges and purge the hoses of air.
