We have an LG Tromm washer model# WM2688HNM. The display says "error, no water supply, check tap and hose" we have tried everything, including having a repair man try to fix it. Water seems to be going in, but it is not draining. What could it be?
I have give the same solution in other post, here it is :
usually problem with semi auto washing machine is on the sensors , exactly in the water level sensor, please check the hose that connected to water level sensor, make sure no dirt blocking or clogging the hose. also you can clean the tube under the pulsator, usually there is many dirt blocking the hose line.
the problem is in the hose leading to the water level sensor, if there is no dirt and looks normal, water level sensor must be replaced
For this error code you need to check both the water heater or
element and thermistor, basically the washing machine is reporting a
fault on the heating circuit with this fault code but it is not capable
of identifying exactly where the fault actually lies.
On non-display panel models this fault code is denoted by the lights for 95, 60, 40 and cold being lit or flashing.
