Question about Palm V
Transfer my Address and Calendar data from Palm Vx to MS outlook
I would like to transfer my Address and Calendar dates from Palm Vx to a Samsung B5722 Handy (Dual-Sim-Function). Therefore, I need a way to transfer my Pam Vx data to outlook.
How could I transfer my Address and Calendar data from Palm Vx to MS outlook?
Tank’s for your help!
Best regards
Dieter
  • Anonymous Jul 24, 2010
    I am living in Germany and the phone store is not able to help.
NinaE
    President:
  • 3,278 Answers
Hello, Dieter.
Go to Start-->Programs/All Programs-->Palm-->Pim conduit sync--> Sync with outlook.
The most current desktop software for your device is here:
http://kb.palm.com/wps/portal/kb/common/article/37014_en.html
If you don't have this version, do not uninstall your previous version, but install this version over your existing one.
Hope this helps.
Posted on Jul 24, 2010
Joe Hogan
  • 10,865 Answers
Hello. Take both devices to your phone store. They will transfer the data for you. J.
Transfer calendar info from Tungsten/E Palm to iphone 3GS
The best way is to transfer the Calendar and Contacts to Outlook. The iPhone can then be synced with Outlook.
Unfortunately, tasks and memos do not transfer. You will need to find other 3rd party apps that are supported on the iPhone and transfer your data to them.
Two examples are:
1. Evernote - This is good for memo. You can export your memos and then import them into Evernote. unfortunately, when I did this, it was a bit tricky. I even had to write a little PERL script to create the format that it wanted.
2. RemembertheMilk - this is a todo application
Jan 03, 2010 | Eforcity Apple iPhone 3GS 16GB / 32GB...
How to move my calendar from Palm m500 to iPhone?
Two examples are:
Jan 03, 2010 | Palm m500 Handheld
Transfer contacts and calendar from Palm to iPhone and iCal
Two examples are:
Oct 04, 2009 | Palm Tungsten E2 Handheld
Handheld Calendar Does Not Sync
Is KsDatebook compatible with Palm? Palm suggests only two programs to sync calender files with Microsoft Outlook and the one that comes with the TX CD.
Jun 04, 2008 | Palm TX Handheld
Sync Outlook 2000
You can transfer your contact list, but not your calender. Here are the steps to take to successfully transfer your contact list from outlook 2000 to the iPhone:
1. In Outlook, export your contact list as a Comma Separated Values (Windows) file
2. In windows accessories, launch Address Book
3. Import into Windows Address Book the file you created in step one
4. Now back in iTunes, sync your iPhone contact list with Windows Address Book
You contacts should come over intact.
Sorry, but there is no solution that I know of to import Calendar events.
JAF
Oct 19, 2007 | Apple iPhone Smartphone
How do I copy address book and calendar from Tungsten E to Outlook?
In order to synchronize with Outlook you need to setup the replication to be with Outlook instead of Palm Desktop. On you cd there should be a third party piece of software (Chapura). Install the required software and follow the instructions.
Sep 12, 2005 | Palm Tungsten E Handheld
Cannot SYNC Outlook Calendar and Contacts
Probably one of these issues - your data is there but you are looking in the wrong place. I am trying to sync my outlook calendar and contacts via Hotsync on a Palm IIIc. It gives me the status of OK, but nothing shows up on the Palm. I have set the custom on Hotsync to desktop overwrites handheld, but still will not work. Thanks.
Sep 11, 2005 | Palm IIIc Handheld
Time difference
Try to reset your time in your phone and try synching
Sep 11, 2005 | Palm M100
How do I transfer Palm m105 data files to MS Outlook
You supplied very little detail here on what you are starting with and what you hope to finish with. Are you synchronizing today and where does the data reside on your PC - in Palm Desktop? If you have all your data in the m105 and wish your Contacts, Calendar, Tasks and Memos to synchronize with your Outlook profile, then install the Desktop software that come with the m105. You will be given the option to synchronize with MS Outlook during the installation. Choose this. The data in your Outlook profile (root level folder only) will merge with the data inside the m105.
Sep 11, 2005 | Palm m105 Handheld
Corrupt Date Book Fixed
Updated Instructions Simple fix for a corrupted Date Book sync error (at least it worked for me on my Treo 650). 1). Turn off 'Show Calendar Event' in the Phones 'Options - General Preferences' menu. 2). Turn off phone. 3). Set the Date/Time to the maximum limits (12/31/31) in Preferences. 4). Open the Calendar and view the maximum day 12/31/31. 5). Select 'Purge - (Delete events older then 1 week)' in the Calendars Options menu. 6). Reset the Date/Time to the current day in Preferences. 7). Hotsync (Desktop Calendar overwrites handheld). 8). Hotsync again to make sure you don’t get the error (Synchronize the files). That’s it. =============================== Outlook Calendar The attempt to open the database failed. Date Book application database is not found. Please invoke the Date Book application on the handheld once and re-synchronize. OLERR:05-0001 OLERR:0D-0004 OLERR:0D-0001 - Not Synchronized Outlook Calendar synchronization failed OLERR:15-0002 OLERR:06-0001 ===============================
Sep 07, 2005 | Palm Treo 650 Handheld
Palm V Logo
Top Palm Computers & Internet Experts
NOEL
NOEL
Pcm2048
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
