Stanley Proto Stanley Magnetic Stud Finder Logo
Posted on Jul 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stanley studfinder won't calibrate; just keeps on beeping and going through the checks
Bill Boyd
Level 3:
Top Expert:
  • Stanley Proto Master 53,816 Answers
  • Posted on Apr 30, 2017
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11948306
Points
172802
Replace the battery and if it still doesn't calibrate then junk it
1helpful
2answers
How to calibrate stanley 400mm digital level
Select a location that is relatively level and flat.
The edge of a bench is best so that the level can be placed in the same position when the level is rotated during the calibration process.
To calibrate follow below:
Press and hold Calibrate button for about 4 seconds. The display will now show CAL1.
Press the Calibrate button briefly again and the 1 will flash, a beep will be heard and CAL2 will be displayed.
Rotate the level 180° end to end with the display still facing you whilst the level is now upside down. Place the level in the same location.
Press the Calibrate button briefly one last time. The 2 will flash, a beep will be heard and the display will revert back to normal.
Red light doesn't go off on stanley studfinder
Hi Laurie,
I think you might have confused the calibration set up in the first step of the directions. This must be done each time the unit is powered on, placed on a different wall, or whenever it is providing ambiguous indications. For you convenience, I have pasted the operation manual below. You should download and review the entire manual - free of charge here.
1) Hold the Stud Sensor 50 flat against the surface making firm contact.
2) Press in and hold the activation button. The green
and red LED's will light. When the red LED goes off,
the unit is calibrated
. Keep holding the activation button
during all of the following procedures.
Note: While calibrating, the Stud Sensor 50 must not
be placed directly over a stud, dense material such as
metal, or over a wet or newly painted area, or it will not
properly calibrate. If the Red LED stays lit, move to
a different location and try again.
2) Slide the Stud Sensor 50 slowly across the surface
in a straight line. As it detects a stud edge, the red LED
will go on.
Use the handy pencil notch located at the top of the
unit to mark the stud edge.
3) Repeat the above steps from the other side of
the stud. Coming from the opposite direction, mark
the other edge of the stud. The midpoint of the two
marks indicates the stud center.
Cautions on Operating
The proximity of electrical wiring or pipes to the surface
of the wall may cause the Stud Sensor 50 to detect
them as studs. You should always use caution when
nailing, cutting or drilling in walls, ceilings and floors
that may contain these items. Always remember that
studs or joists are normally spaced 16 inches or 24
inches apart and are 1-1/2 inches in width. To avoid
surprises be aware that anything closer together or of a different width may not be a stud.
I hope this helps & good luck!
I have a Stanley IntelliSensor Pro. It's worked fine for a couple of months. Now it won't calibrate - it just flashes quickly calibrating, and alternatively flashing the centre (bullseye) ci
I hate to tell you this as you are an electrician but often it is best to look for the simple solution. My Stanley IntelliSensor Pro was doing the same thing here is the answer:
CHANGE THE BATTERY
Red light would not go out and beep would not stop when moving finder across wall.
I had this problem as well. The solution was to replace the 9 volt battery that it runs on. The beep was much louder and it calibrated correctly. Apparently the old battery was enough to make the beeping sound but not strong enough to emit the energy required to penetrate the drywall.
I have plaster walls in an old house the stud finder just keeps beeping how does this thing work?
Your stud finder keeps beeping because old plaster walls have lath boards behind the plaster that are attached to the studs and running horizontally. Try adjusting the sensitivity of the stud finder by placing it on the wall and turning the sensitivity down until it just stops beeping. Then move it back and forth in a wide enough arc to be sure that you have crossed a stud, turning up the sensitivity ever so slightly until you get a tone when you cross a stud. Hope this works out for you.
1helpful
2answers
I cannot figure out how to put a blade in my Stanley FatMax fixed blade utility knife. There are no instructions with the knife.
at the handel end it will pull apartthen slide the whats left of the old blade and put new won in its place just do it slowly so you dont forget how it goes
How do I calibrate my stanley laser level
to calibrate you need to have an area 75 to 100 feet in distance. place laser on tripod 20 feet from one end, take measurements on short and long end, then move laser to center of range and take measurements on both ends . the distance between both sets of marks should be within + or - 1/4 inch if not move level screw to move beam to center then center bubble
24helpful
3answers
Harman kardon audio system for harley davison not calibrated
i have the harmon kardon stereo for harley and the sound keeps going out on it. This is the fourth unit that the same thing has happened too. Its like the unit goes into mute mode but its not. everything works but the sound. can u help me please.
Top Stanley Proto Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Stanley Proto Measuring Tool and Sensor Expert? Answer questions, earn points and help others
