Jensen A300HLX Car Audio Amplifier Logo
Question about Jensen A300HLX Car Audio Amplifier
How do i hook up my jensen 300watt a300hlx to
How do i hook up my jensen 300watt a300hxl to previous wiring from previous kenwood amp i have a 2006 dodge charge?i have thick blue wire that runs from front of car back to where previous amp was located,also a thick silver wire,small blue wire(remote)
Posted by jess_wright2 on
4 Related Answers
SOURCE: jensen xa2150 amplifier
Check and see if its dirty inside, dust and smoke are known to cause problems via shorting or not making contact... sometimes your fuses are a bit over the wall so it would be best to replace them... and check if you have a fuse between your battery and the power cable to avoid over powering the amp
Posted on Dec 19, 2007
JULIANFIX
ALBERT GARCIA
  • 975 Answers
SOURCE: A300HLX Amp + 600 Watt JL Audio Sub
Ill go for a better GROUND , sounds like its not grounded properly and thats why the RED LIGHT . DO A RE CHECK on the installation . hope this helps
Posted on Apr 29, 2008
Anonymous
SOURCE: Please help.... I need a wiring diagram or pinout for my Jensen xa1120 amp, thanks
xa 1120 amp pin out 123
456
1 left neg
2 ground to radio
3 left positive
4 right neg
5 blank-not used
6 right positive
Posted on Oct 10, 2008
Anonymous
  • 41 Answers
SOURCE: recently my system[jensen 300watt amp]started
It is mostly a ground hum. You can fix this problem by buying a ground loop isolator. Another problem you may be having is the preamps on your stereo unit are bad.
http://www.radioshack.com/product/index.jsp?productId=2062214
Posted on Jun 24, 2011
I have an older model Jensen 500 watt 2 channel bridgeable amp. When i hook it up the red light(protect light) comes on and it will not work
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS AND POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
My amp has alot of feedback in the amp
usually because of bad ground try using a wire brush to remove any corrosion, paint, and or rust under ground wire
Jenson a300hlx 300 watt amp
DISCONNECT THE GROUND WIRE. SAND ALL THE PAINT FROM THAT AREA AND REGROUND IT. WHAT I WOULD RECOMMEND IS DRILLING A HOLE THROUGH THAT TRUNK, SAND THE PAINT AWAY FROM WHERE THE GROUND WIRE WILL GO AND BOLT THE GROUND WIRE TO THE TRUNK BOTTOM. THE PAINT WILL CAUSE THE AMP NOT TO GET A SOLID GROUND
Jensen Amp and Sub
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Car amplifier weak
if you have a 25 Watt amp (per speaker) then go to radio shack and get (2) 50 watt resistors (8 ohms each). attach them like speakers. turn it on half volume. they should get quite warm to the touch.
2answers
Kenwood kac-9152d
by jump do you mean all it does is thump and no sound besides thumping noise? if so put a better ground on your amp, double grounds work the best. please reply
Top Jensen Car Audio & Video Experts
ZappaNut
ZappaNut
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
