I have a sony trinitron 36" flat screen tv. The unit was purchased in 2002. We had an electrical storm but tv was off. The next day the tv has a picture (shakes) with a solid green vertical line on the left side of the screen. Small horizontal lines along the top of the screen. any ideas? Thanks
Unfortunately, TV sets are not equipped with adequate internal protection against electrical storm damage, and it doesn't matter that the TV was turned off if it was left plugged in to an active electrical receptacle and/or directly connected to an antenna or an Internet data line. The fact that you can still receive anything at all indicates that the TV set can probably be repaired at a service shop, but for future protection of the set you should purchase a good surge protection device such as the one found at the below link.
Amazon com APC 11 Outlet Surge Protector 3020 Joules with Phone Network...
SOURCE: Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
SOURCE: how do i adjust the vertical hold on my sony
take the back cover off there shoulde be one or more little knobs so you can adjust the tv
SOURCE: have sony 36 trinitron about 5 years or older..the
U have magnatic degausing coil problem.Take the tv aparts,there a solid back coil all around inside the front frame of ur tv.That the cause,unplug that coil,should not effect the tv pic if have no magnatics problems.
SOURCE: My Trinitron 36 inch XBR Sony makes horizontal
My TV has the same exact problem, Please let me know if you got any solution. My email is [email protected]
