Question about Lexmark Wheelwriter 1000 Typewriter
Nothing happens when you plug it in & turn it
Nothing happens when you plug it in & turn it on
Dick O Reilly
  • Lexmark Master
  • 3,594 Answers
First be sure it is plugged into a working outlet, try another power cord (a 3 wire computer cord will work) look on and around the PC board for vdebris. If these don't help byou probably need a tech.
DickyO
Posted on Aug 10, 2010
I have a peavy classic 100 2x12 1975 has a high pitch squeal coming out of amp when powered on
If this happens only when the guitar is plugged in, most likely there are two possibilities. The first, you have some issues with the electronics in the guitar OR are using an acoustic guitar witch has an extremely sensitive pickup that provides nothing but feedback. If this is happening with the guitar unplugged, there is a mountain of possibilities.
Sep 01, 2014 | Music
Nothing happens when push start button. power cord etc good ??? is this a power unit failure?
make sure the outlet is recieving power
unplug the tower from the outlet & then replug it in & see what happens
make sure all cords are plugged in correctly in the back of the tower
then if nothing happens after you push the start button, power supply & cord could be bad
the same thing happened to my daughter's pc & had to replace power supply & shorted out the motherboard
Nov 18, 2010 | HP Compaq Presario SR2050NX PC Desktop
GATEWAY E4000 Desktop P4 1.8GHz ,768MB doesn't recognize monitor
Try pulling the ram chips out and see if it turns on.
pull out the cards and unplug the cd and hard drive and see if it turns on,,
If you have no luck then its a bad cpu or motherboard,
Apr 10, 2010 | Computers & Internet
Sidekick lx2009 wont turn on & when charging it turns on & OFF!
try plugging it in to the computer or try a new battery
Sep 01, 2009 | Sharp Sidekick LX Smartphone
Lexmark Wheelwriter 1000 Typewriter Logo
102 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
