I put aspect in "zoom", which just made the picture wider. There is no adjustment to the zoom setting.I put aspect in "zoom", which just made the picture wider. There is no adjustment to the zoom setting.
If you have Dish Network, the asterisk button change the TV from, Stretch, to Partial Zoom, to Zoom, to Grey Bar, and back to Normal.If you have Dish Network, the asterisk button change the TV from, Stretch, to Partial Zoom, to Zoom, to Grey Bar, and back to Normal.
You can't post conmments that contain an email address.
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
I have the same problem with a 40" Toshiba LCD, Component cables work fine with FIOS but not HMDI, goes in and out then blank. HDMI with DVD player works fine. Best buy reported this same problem from users with this toshiba lcd but no solution.
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
No adjustment for horizontal width in the owners manual.
