Question about Ximeta (NDU10200CU)
ION Network, Ximeta NDAS Network storage device.
I have recently switched computers from Windows XP SP2 to Windows Vista Premium. While operating under Windows XP SP2 I had no problems accessing and writing filed to our NDAS Network storage device. I have since installed the device on my computer with Vista and can access the device and even see folders on the device but when I try to open certain office documents an error message saying that there was a problem accessing the document and that I would need to - check to make sure I have enough storage, -make sure I have permission to open the document from the administrator, or -to run recovery and repare to open the document. I have tried everything except reinstalling Mircosoft Office 08 to see if there is a problem there. All of my drivers are updated (after a thourough check) and I have checked to make sure that the administrator has given me permission to read and write files on the device (which has been made open to the public). Is there a Windows patch that might help me or should I proceed to reinstall Microsoft Office 08?
Posted by Jagland on
2 Related Answers
Anonymous
SOURCE: changed computers. new computer has vista, cant load software
downloade new software from ximeta.
Posted on Dec 24, 2008
gribas
SOURCE: win 7 64 bit freeze
I have the same problem. I don't have the right solution but I discovered a workaround.
The problem occurs everytime when I install a windows 7 update.
My work around:
  1. When Windows determines an update I disable the NDAS service with msconfig
  2. The update is installed without the NDAS service operational.
  3. After update I enable the NDAS service with msconfig
  4. I restart my computer. Then it freezes.
  5. After a hard reset, the computer restarts in Safe modus. I restart my computer and my computer works, till the next windows 7 update. Then I start again van 1.
Very suboptimal, but it works.
Anton
Posted on Aug 10, 2011
Win 7 64 bit freeze when starting XiMeta's NDAS NetDisk. I'm using newest version 3.72 from Ximeta website.
My work around:
Anton
Jul 08, 2011 | Ximeta (NDU10200CU)
Ximeta ndas not connecting
Check the cables first, try a different one
May 26, 2008 | SmartDisk NetDisk (END160) 160 GB Hard...
I am trying to scan multiple documents and have them go into 1 file using Windows fax and scan with my HP3020 all in one printer scanner, this used to happen automatically when I was on XP but recently...
This is the latest version of HP's Universal Print Driver (UPD). The UPD, available in 32 and 64 bit packages, is a single driver that supports PCL5, PCL6, and HP PostScript; level 2 and 3 emulation.
Please review the Release Notes for information on issues resolved, performance improvements, and new behavior changes to the UPD.
Details and specifications File name: s.gif upd-5_1_1_8232-pcl5_win-xp-vista.exe [1/1, 14.6M] System requirements: s.gif Client and server operated systems supported for the most current release of the UPD:
Client operating systems supported:
  • Microsoft Windows 7 Starter, Home Premium, Professional, Enterprise, and Ultimate; x86 and x64
  • Microsoft Windows Vista Business, Enterprise, Home Basic, Home Premium, and Ultimate; x86 and x64
  • Microsoft Windows XP (SP2 and later) Home Edition, and Professional; x86 and x64
    *Note: Microsoft retired mainstream support for Windows XP in April 2009. HP will continue to provide best effort support for the current UPD and tools for the discontinued Windows XP operating system until 2011
thumbs back!
Oct 28, 2010 | HP LaserJet 3020 All-In-One Printer
I Need Windows XP Drivers for Sony VAIO VGN-NS10L/S Laptop
Good day!!! I know the link for the VGN series for windows XP drivers you can download the drivers there ( http://www.getpcmemory.com/drivers/download-sony-vaio-vgn-series-notebooks-windows-xp-drivers/ ) hope this one can solve your problem.Cheers and God Bless.
Jun 23, 2009 | HP LaserJet P2015 Printer
Can't use VPC-CG9 as PC camera.
I don't know why this wouldn't work on Vista HP, but this excerpt from the manual suggests that your XP SP1 Pro would not work without the SP2 rollup:
"Please perform the following upgrades before connecting the camera to a computer.
-Upgrade Windows XP to SP2.
Install Windows XP SP2.
-Install Windows Messenger 5.0 or later version.
Download Windows Messenger 5.0 or later version, and install it.
-If using MSN Messenger, please install MSN Messenger 7.0 or later
version."
Perhaps if you are following the steps exactly in the manual and it still does not work, upgrading Messenger will magically help.
Mar 24, 2009 | Sanyo Xacti VPC-CG9 Digital Camera
Windows vista to windows xp sp2; the VGA and wireless don't work
uninstall the wireless driver and then reinstall it again and then install the vga driver and do the wireless configuration from the router page,and then try and install the wireless driver of xp and also install the vga driver of xp.......good luck.....
pls rate this solution
Feb 16, 2009 | Microsoft Windows Vista Home Premium with...
NDAS is the utility
ahh..I see..so what precisely is your situation, and what's your questions?
Mar 26, 2008 | Ximeta NDU10-80 80 GB Hard Drive
Ximeta External Hard Drive
You need to stop using Vista as Microsoft has not supported it since 2014. OK to use Vista for a while after 2014 because Windows Update still gave security updates for other Windows products (Word, Works, etc.). But now, Windows Update for Vista will not work anymore for anything. At least switch to Windows 7 as Microsoft will probably support it until 2020.
Dec 15, 2017 | Ximeta (NDU10200CU)
XiMeta's NDAS NetDisk and Windows Vista Blue Screen
Take a look at this: http://www.ximeta.com/forum/viewtopic.php?t=13. The patch from Microsoft worked for me.
Feb 20, 2008 | Ximeta (NDU10200CU)
Ximeta (NDU10200CU) Logo
223 people viewed this question
Top Ximeta Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Ximeta Computer and Internet Expert? Answer questions, earn points and help others
