Acer Aspire  T690 (AST690UP820A) PC Desktop Logo
Question about Acer Aspire T690 (AST690UP820A) PC Desktop
Can your Hardware (network/monitor) cause your computer to freeze, crash/restart on its own? The reason I ask is the I'm trying to fix a computer that when use online it seems to freeze/crash at first I believe it to be the monitor/ VGA card due to some lines appearing on the left side of the screen but it seems to only crash when connected to the internet plus Ive already check with another monitor offline and it didn't seem to crash.
  • Anonymous Jul 24, 2010
    Also I've downgrade the software from vista to home XP(so it cant be virus related), but the problem still happened on XP which was the same thing on vista using both Internet explorer and Mozilla. Its seems to be related to the network card or the video card but I am leaning to the network card.
    I imagine that maybe by installing a PCI network card, I could figure it out right?
Azrael SRL
  • Acer Master
  • 11,800 Answers
Of course, but it should be a major failure that would make them practically unusable - not your case. You most likely use IE and it's a POS that crashes with regularity when it's encountering a more demanding site. Just use another browser and your problem  will go away. Don't forget to scan your pc for malware before.
Posted on Jul 23, 2010
  • Azrael SRL Jul 24, 2010
    Yes, installing another LAN card would make it clear if it's network related, but as i said there shouldn't be. BTW before installing the new card uninstall the driver for the old one and disable it from BIOS.
Anonymous
    New Friend:
    Problem Solver:
  • 7 Answers
This can be because of excessive use of memory or use of restricted memory location by the program's data or instruction.So the computer must restart for the safety reasons..To minimize the problem uninstall the program which on opening gives rise to the problem.
Hope this works. If not fell free to reply.
Posted on Oct 08, 2012
After having unplugged my computer from router for a period of time when I hooked it back up I get no signal msg on monitor how can I fix it
Troubleshooting Network Problems on the Dell V525w and ...
www.dell.com/support/article/us/en/04/SLN129390?c...l...
DellMay 13, 2015 - My Account .... Back to Top ... The printer, the computer, and the access point (wireless router) are ... Try unplugging other devices that may cause a conflict with the USB ports. ... with only the VPN and no other network at the sametime. ... message during installation indicating that the printer does not have ...
Connection Keeps Dropping Off - NICs - Components - Tom's Hardware
www.tomshardware.com > Forum > Components
Tom's Hardware Guide
Mar 8, 2010 - 30 posts - ‎23 authors
I will sometimes lose my internet connection within windows. ... When I hook up the cable modem directly to the host PC everythinh ... My desktop has a linksys wireless NIC and I have no problems with it ... Comcast says when the cable box loses it'ssignal, the router can't get good communication back with ...
No Signal Message On Monitor And PC Gets Restart?
forumarray.com/no-signal-message-on-monitor-and-pc-gets-restart-1421...
Nov 18, 2015 - started recently, when I boot my PC, the screen shows message: no signal and screen stays dark. ... then to get the signal back again, i must restart mysystem. then after boot up, i get ... Dell :: Having Trouble With Display On External Monitor .... laptop screen working until I unplug the 2nd monitor and restart my computer. What Is A Signal Cable On The Computer - Logo
Jan 17, 2016
BSOD When Unplugging Ethernet Cable - Logo
Nov 19, 2015
Monitor Doesn't Get Signal From Computer?
Nov 13, 2015
Cable Unplugged Network - Logo
Mar 22, 2013
More results from forumarray.com
2answers
My computer crashes or freezes a lot
It might be a virus.
Probably Lsass virus. This virus can get into your computer and really cause havoc with your network connections and also deny you access to certain internet sites.
You need a Lsass removal tool.
try to go here http://www.symantec.com/security_response/writeup.jsp?docid=2004-050114-1706-99
and download the tool, and follow the instructions.
good luck
1helpful
PC crashes repeatedly, sometimes comes back on, screen says this!
this problem is cause by some hardware components. just make sure all of your hardware components are fixed correctly with mainboard. or else, if you installed any new hardware options to your computer, just remove that & try to start the computer.
if you still have that problem, just let me know!!
When i load up my windwo it freeze on please wait screen
aw I think you have problem in hardware, software or user.. hardware means there are parts of your computer hardware that have a glitch or uncompatible, software maybe you have been virus or you installed uncompatible programs, user unproper management of computer like unproper shutdown.... that cause the system or hardware to crash....
Try booting in safe mode by pressing F8 when you turn on or restarting the computer, if a boot selection appeared select your primary hard disk then select safe mode.. after good start up in safe mode uninstalling the new software that you install if there is then restart the computer properly. if you install a new hardware try to take it out and turn on again the computer... TY
HOPE I CAN HELP
CLCSITE
1helpful
Antivirus 2008
Freezes and crashes are generally caused by some sort of instability in the computer system.
The following is a list of specific problems that can cause instability along with what to check when troubleshooting each.
Viruses can cause instability.
Run a virus check on the computer to look for a possible virus.
Conflicts can cause instability.
Check the Windows Device Manager to see if there are any yellow exclamation marks or red Xs beside the listings for device classifications. If there are, contact Tech Support.
Buggy or damaged software applications can cause instability.
If the system is less stable when certain software programs are running, shut down those programs and see if the problem continues to occur. If the problems stop, chances are that those software programs are causing the problems.
Buggy, outdated, or conflicting drivers can cause instability.
Check manufacturer web sites for updated device drivers for the various devices installed on the computer system, such as: printer drivers, modem drivers, video drivers, sound drivers, USB device drivers, etc.
Update one driver at a time and see if the system stabilizes. If this doesn't work, it may be a hardware problem, so contact Tech Support.
AC problems can cause instability.
Check to see if the computer system is plugged into an overloaded outlet.
Make sure the computer system is plugged into a surge suppressor.
The installation of new devices can cause instability.
There are three typical symptoms that point to this problem:
The computer system fails to boot, freezes during a boot, or freezes during an operation for no apparent reason.
The system fails to recognize the newly installed device.
One or more software applications fail to function as expected after an upgrade.
Some Tips for Dealing with Freezes and Crashes
Keep track of the hardware and software that is added to a computer.
The addition of new hardware and software can often cause problems to occur.
Research the compatibility of new hardware and software with the existing computer system before purchase and installation.
The older a PC, the more likely it is to crash.
When a computer freezes or crashes, chances are that changes made after the last save and when the freeze or crash occurred will be lost.
2helpful
3answers
Desktop freezes and can't do anything!!!!!
I suggest to you do the follow:
Start up your computer and before windows load hit F8, then select SAVE MODE
On SAVE MODE, uninstall all innecesary programs or recently installed, Clean your computer, and be sure that your computer is not virus or spyware infected.
After that reboot and work normally
This will be fixing your problem.
If the problem after that continues is probably then that your have some hardware issue.
Thank you for using FIXYA
Don't forget to rate my help!
Pablo :-)
Problem with windows xp service pack 2
Windows was unable to save all the data for the file drive_letter:\file_path\file_name. The data has been lost. This error may be caused by a failure of your computer hardware or network connection. Please try to save this file elsewhere.To restore normal behavior:
1. Open a CMD.exe window.
2. Type the following command and press Enter: REG ADD “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\3ware Storage Controller” /V CacheControl /T REG_DWORD /D 0 /F
3. When you receive the The operation completed successfully message, shutdown and restart Windows XP.
Steve Sweetleaf
Steve Sweetleaf
shadow
