Dk Multimedia Eyewitness Encyclopedia of Space and the Universe Full Version for PC, Mac Logo
Anonymous Posted on Jul 23, 2010
I have a finnish version of Eyewitness encyclopedia of space and the universe, it worked years ago on our old computer but now I can't get it working on our new one.. the installation will not complete, what can I do to make it work? the installation window just stops responding when the loading reaches 100%
Level 3:
  • Master 6,688 Answers
  • Posted on Jul 23, 2010
Cindy  Wells
Master
Level 3:
Answers
6688
Questions
0
Helped
3529919
Points
21744
What OS does your new computer have? What was your old OS? Unfortunately, install codes do change with OS versions and a program for a much older program will not run on a new OS (esp for Microsoft products). This program (in its English Windows version) was coded to run under Win95-WinXP; it probably can't run under Win7. You can try installing in the compatibility mode (for Windows - right click on the installer and select properties and the compatibility tab). However, this doesn't always work. It isn't a program listed in the Windows Compatibility Center for Vista or Win7 (although the Vista version is confused with its search results - 47 items found becomes 11).
Another option is to install an OS that will run the program as inside a Virtual PC program or as a dual-boot option. (Win7 Pro and Ultimate allows you to install XP mode free (a virtual XP computer after you download and install two programs from Microsoft).) Otherwise you will need a valid licensed copy of the OS you need.
I wish that I could be of more help.
Testimonial: "thank you for your answer, I'll try your tips :) we have win7 now."
From finnish to swedish
For the XP version:
1. Click the "start" button
2. Select "Control Panel"
3. Select "Regional and Language Options"
4. Select "Language" Tab
5. Change to Finnish
Encyclopedia of space and the universe version 2 wont install says wing 32 dll missing xp and vista same
Hi willharris_s
Runs only under 32 bit systems in Windows . Your cdrom could be defective . Make sure you have fully deleted previous version .
Best regards ,
fanaudi .
1helpful
Am using version 2.0 with windows xp but it says it has a sound issue. and when i look at the readme it gives instructions only for windows 98. do i need a patch to run on xp and if so where do i get it
There is no such thing, the firm that has created this program has never had to create one because the program is made for XP. The problem is generated by a bad option in its settings - either go into the Options and solve it there (follow the 98 instructions, the work very much the same) or uninstall the program, delete all remaining folders it has left behind in C / Docs and Sett / name / Application Data, then run a registry cleaner like
http://www.eusing.com/free_registry_cleaner/registry_cleaner.htm
then reinstalling it in a different location.
1helpful
I have original eyewitness encyclopedia space universe cd. but when i install it a error message shown in the computer. "[1058] the sound decompression software has not been install properly. please...
Hi ,
This product is not compatible with Windows 7 but it should run under Windows XP . If you are running under XP , I suggest you delete the program , reboot your machine and reinstall the program under Windows XP . If it still fails , you could need to reinstall Win XP or use the recovery disc . Launch the disc , select " install a new version of XP " and choose " repair " when you'll be asked to .
Make first sure you have installed SP3 and tested your program with XP fully updated .
Best regards ,
fanaudi .
I want to de-install microsoft encarta encyclopedia professional 2002 but I always get the request to insert the installation disk which I do not have. The programme is 1.6 GB and I really do need space....
Hello
It will gives the same message till the disk were inserted, you can get free space by deleting Encarta folder in drive c, program files folder.
Hope it helps, if so do rate the solution
Recently tried to run DK Multimedia Encyclopedia of Space and the Universe and I get a 1058 sound decompression error. Ik about the patches for xp but i have vista and they dont seem to work. any help?
try this, Run as Administrator and set the program EXE to Compatability Mode for XP SP2, and also, run as Administrator, do this for everything, patches included.
Cant run nature in windows XP pc
Hi there. You can run your software on Windows XP with no problem. The software is compatible with Windows XP.
How to get science 2.0 to run on vista will 16 bit programs not interface with 32 bit computers
Maybe it is possible to chance the compatibility for the program to a older windows ex windows 2000. To find this go to the icon of the program on your desktop, select it and then right clik on your mouse, choise properties and the choise the compatibily tab and choise there a older windows.
Please rate my answer !
Top Dk Multimedia Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Dk Multimedia Computer and Internet Expert? Answer questions, earn points and help others
