Porter Cable Cable Commercial Pressure Washer PCH3200 Logo
Posted on Jul 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine manual for the Porter Cable pcv 2250 pressure washer
I need a engine manual for the Porter Cable pcv 2250 pressure washer
Anonymous
Level 3:
  • Master 760 Answers
  • Posted on Jul 23, 2010
Anonymous
Master
Level 3:
Answers
760
Questions
0
Helped
490685
Points
2276
If you need an engine manual, then look up the manual on the engine manufacturer's web site. eg Briggs & Stratton, Honda, Techumseh. Porter Cable manual would just have cart and pump info.
What is the spark plug gap?
Hi Mike,
If you can identify the model of Honda engine on the washer, you can download the service manual from this webpage:
http://engines.honda.com/models/application/pressure-washer
Hope this helps!
What type of gas do i use
Regular 87-89 octane gas workes (unleaded)
What grade of oil do you put in the pump not the engine
Pumps use a 30-weight non-detergent pump oil. Don't use motor oil.
1helpful
No pressure
you will have to try the following start up purge up onece with just water then start the powerwasher if that does'nt give u pressure ther is gaskets inside the pumping sometimes 4 to 8 of them these might be to wore down to hold pressure if u can locate the pump and desemable it run it to ur local dealer tell u need new gaskets put into it
Hot water coming out of a cold water pressure washer
This sounds like a heat transfer problem
You should check that the oil reservoir for the pump has oil in it. It sounds like it may be low. Also, if it is a gas model, the engine oil may be low.
Remember the pump oil reservoir should be only 1/3 to 1/2 full of non-detergent oil.
2helpful
Porter Cable pcv2250 pressure washer shooting water out of siphon
non return valve on syphon injector on high pressure outlet stuck or 'o' ring worn. remove barb should be a spring and ball bearing in there.
it may be that the spring has broken too.
new non return valves are available.
Top Porter Cable Garden Experts
Jay Finke
Jay Finke
john h
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
