Terk XMDirect Satellite Radio Receiver Logo
Question about Terk XMDirect Satellite Radio Receiver
ON THE XMDP10110,COULD YOU TELL ME WITCH WIRE IS POSITIVE AND NEG THIER BOTH BLACK,ONE IS IS PART OF THE DIN CABLE
Posted by mpsaltydog on
2answers
How can I tell which cable is pos and neg? I changed the old ones with new and I think they are crossed.
The ground goes bolted to the engine block, n chassisthe positive to your alternator.
I put a new stereo in my 2000 model n16 but I
on after market fit radio's the yellow wire is to go to permanent power via a fuse , and the red is to go to ignition live via a fuse and ofcourse the black for the earth no fuse unless connected directly to battery neg terminal
2answers
How do I hook a 6 Volt Battery up on Farmall Cub Tractor
look for positve on battery a + sighn is what you are looking for on battery then find positive battery cable in tractor no witch it between pos cable neg cable hook neg to battery fist to battery then hook up positve cable ready to start
Sep 02, 2014 • Garden
3helpful
Pinout Details for HP C7671B transparency adaptor mini din connector
Cut the mini din wire, you will see four wires inside the sleeves. The red wire is positive terminal, and black wire is negative terminal. Use any 12V DC adapter to connect. The adapter will light up. Good Luck.
Have 2 4+4ohm avi sl500 subs how do i wire it to this amp and what setings on this amp alpine mdr m1005 1000watt amp
using these subs will limit you to a 4 oh load to the amp witch will only let the amp produce half of it's power. the lowest ohm load that amp can handle is 2 ohm and the next lowest you can wire the subs is 1 ohm and that will over heat the amp and destroy it. so to answer your question first wire each sub like this diagram shows...
Wiring Option #1
then once both subs are wired this way you wire both positives from each sub to the positive side of the amps speakers terminals and wire each subs neg. to the amps neg speakers terminal. the wire is series parrelle and will present a 4 ohm load witch will be the safest to run with your amp.
8 wires on my subwoofer??
"One has positive and negative input, another positive and negative output (red and black on each)"
Just from your description, it sounds like pos/neg input are the 12 volt pos neg supply for the amp inside the subwoofer. Red is pos, black is neg.
"positive and negative output (red and black on each)"
This sounds like it's used if you want to proved 12 volt pos/neg to another component.
"and a third wire with left input right input positive and negative (blue, red, yellow and black)"
This is for the cables coming from the "subwoofer out" on the amp. This is 4 wires altogether -- correct?
3answers
Philips fm92 cb radio
Hi there soleman , it was common for Philips to fit fuse holders to both positive and negative wires on their radios , the red with black trace is neg the plain red is positive . Cheers T
Top Terk Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Terk Audio Player and Recorder Expert? Answer questions, earn points and help others
