ViewSonic VE175b 17" LCD Monitor Logo
Posted on Jul 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ViewSonic VE155b "Out of Range" on screen -- ViewSonic VE155b
Anonymous
Level 2:
New Friend:
  • Expert 62 Answers
  • Posted on Jul 23, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
62
Questions
0
Helped
21208
Points
178
this means that your computer is set to either a too high frequency or too high resolution. Try to lower the resolution setting of your desktop step by step, until the message disappears.
1helpful
When i changed my old monitor with ViewSonic VE155B Black 15" LCD Monitor, the beautiful pictures previously stored on my computer appear too dark. i checked the settings of monitor, but the brightness n...
rubina576, I see you haven't looked at the "date of manufacture" on rear of your VE155B!!!! Retrevo .com lists unit as time to retire. The long,"very thin", "cold-cathode-fluorescent-lamps" that provide a "constant" bright, "white light" on the reverse side of the LCD PANEL, have "worn out" and are very "tired"!!!! You can see typical lcd CCFL's at: www.rexim.com and click on "products" you will see "lcd backlights" !!! YOU ARE NOT QUALIFIED TO CHANGE THEM. A technician will need to do it. Very time consuming procedure. If your ve155b menu button on monitor can't fix brightness for you, then your options are: 1. check with viewsonic to cost out a refurbed VE155b if you can. 2. Trade in unit for new wide-screen 2010 or 2011 lcd monitor. If this was of some help, please rate my response on fixya. By for now. 12fixlouie north of Windy City.
AS SOON AS YOU TURN ON THE MONITOR IT SHOWS NO SIGNAL ON THE SCREEN. SO THERE IS SOME POWER TO THE SCREEN OR YOU WOULD GET NO SIGN OF LIFE AT ALL AND THEN IT SHUTS THE SCREEN OFF YET THE POWER LIGHT SHOWS...
Hi! If this is the case, the problem will surely be on the monitor cable going to the pc. If the cable is loose or faulty it will give you a no signal message. YOu will need to secure the cable of the monitor for it to work. Hope this helps and thank you for using FixYa!
1helpful
2answers
Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
1helpful
ViewSonic VA550 problem with horizontal blurryness
try resetting the settings from the menu ....
if the sharpness or the brightness is high you may feel fuzzyness ..
and also just have a check is there any magnetic field placed near by the monitor if so take it some what away and then give deguass option ....
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
How to hook up flat screen monitor??
That's all you need. Just a standard power cord plus the VGA connector cable. Plug the new monitor into the same spot as the old one.
Dan
Monitor says burn -in
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Power saving
Right click your desktop, click properties, click the screen saver tab, it'll say monitor power at the bottom, click power then choose which option you want. Good luck.
2answers
Monitor is on, goes light to dark in 1 second
I have the same problem with my Dell 17" monitor. I've been reading and what others with similar problems say is that the power supply has a bad capacitor.
Monitor
On the monitor there should be an auto adjust button. Press that and it will adjust to your windows desktop.
Viewsonic ve155b Dead
shine a flashlight into the monitor, if you can then see what is usually on your desktop, then your backlight has a problem.
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
