I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Ours does the same and we found that it will continue to block every few months. And when this happens the over heating light comes on. Caveat emptor
I suggest you check if the drain hole at the bottom of the freezer is blocked. The drain hole is on the back of the ledge at the bottom. You can't get at it unless you remove the large panel at the back of the freezer. It may look clear, but could be blocked part way down the drain pipe. I used a small bottle brush to clear ours.
I have had to clear the drain hole 3 times now. I believe the ice build up is caused when the door is left open and too much frost builds up.
It is a pain to keep doing this. I check the defrost cycle and all fans, etc. appear to be working.
It seems to me that the problem is the metal flashing, which doesn't direct the water down the drainage hole sufficiently.
SOURCE: frost free freezer smells like fish
IF THERE WAS A LAYER OF ICE ON THE BOTTOM OF THE FREEZER, THE DRAIN IS PROBABLY PLUGGED UP. IT WILL NEED TO BE CLEARED BEFORE PUTTING BACK INTO SERVICE OR IT WILL JUST DRAIN INTO THE FLOOR OF THE FREEZER AGAIN. AS FAR AS THE ODOR, TRY PUTTING CHARCOAL IN IT TO ABSORB THE ODORS. IT WILL HAVE TO BE LEFT IN THERE FOR QUITE A WHILE. WHEN THE FREEZER IS CHILLED, IT WILL LESSEN THE SEVERITY OF THE ODOR. IF THAT IS UNACCEPTABLE, THERE ARE COMMERCIAL ODOR NEUTALIZERS ON THE MARKET YOU CAN USE.
SOURCE: ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
SOURCE: frost free freezer with ice in the bottom and
Frost Free Freezer have an automatic defrost, which is essentially a heating element which melts any ice. If your door seals are in poor condition or something is preventing the door from sealing the ambient air may be melting the ice more than the drain can accommodate. Check the drain in the bottom of the freezer. Humidity can also cause more water to accumulate, especially if the door seals are not sealing.
