Canon i9950. Suddenly no ink coming from five wells (BK, R, G, PC & PM) despite plenty of ink. Not a speck on the test sheet after several cleanings and deep cleanings. Other inks fine. Printer was idle for about a week but trouble free before.
I have the same problem but it's only with the black ink, I removed the print head unit and run it under the hot tap till th ewater ran clear, then i soaked it in hot water and again run fresh water through it till it ran clear then left it in a bath of alcohol, i just used whiskey, but wouldn't recommend drinking it after, or before for that matter, I felt there was nothing to lose if it was a faulty print head as they are about £95 new. I had already run several deep cleaning programs and replaced the inks, but literally no black ink at all was printing. I havn'e tried it yet as it's still soaking, but I have also stripped the cover off the priinter and am trying to clean otu the waste ink tanks and absorbant pads, it's far to expensive a printer to just chuck out so here's hoping
Brian.
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
