Timex 1440 Nylon watch Logo
Question about Timex 1440 Nylon watch
How can I review the split times on my Timex 1440
How can I review (go back and look at) the split times on my Timex 1440 sports watch?
four buttons: Start/Stop, Indiglo, Mode, Set
  • Anonymous Jul 24, 2010
    Yes, I already read the instruction guide. It came with the watch.
    Nowhere does it explain how to go back and look at split times at the end of the workout/race/etc.
Janelle Schoonover
  • 842 Answers
Set date on 1440 sports watch 504-t5k085
My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
187helpful
Timex 1440 sports wach chime disable
Press the mode button until the Alarm apears. Press the Start/Stop button to turn the alarm on/off and remove/add the chime. Whew! I had to figure this out after my 3 year old turned the chime on!
I have a Timex 1440 sports watch. I have Parkinsons and must take medicine on a specific timed schedule. For a while all was well with this watch; the alarm rang when set. However, I think I inadvertently...
I think you just turned off the alarm. You need to press the MODE button until you are in the alarm mode. (AL or ALARM on screen), then I believe that you just need to click on the upper right hand button (strat/split or stop/reset) repeatedly until the alarm goes back on. Hope this helps.
Need instructions for Timex 1440 Sport watch
just press the lap/reset button then press the mode button a letter A should appear
67helpful
10answers
Timex 1440 sports WR50M
Solution #2 by Guest, posted on May 13, 2008 solved my problem. OUTSTANDING solution #2!
1. Hold in the MODE button until the alarm time appears.
2. VERY IMPORTANT - release and TAP the MODE button AGAIN, and the time should appear with the seconds flashing.
3. Use StART/Stop to choose among seconds, hours, and minutes, and
4. Use ADJUST to increase the selected number
5. Press MODE to put the thing back in regular operational mode.
After several attempts with other directions over the last four months, these 5 steps WORKED.
Timex 1440 Sport watch needs a new strap
Hi I have a 1440 sport watch , somehow I got it into 24 hr mode vs regular time. Can't seem to figure outhow to get it out of this.....HELP :)
2answers
Stting the time
http://assets.timex.com/instructions/w3Instr.pdf
Try the link above for a manual.  It is NOT the same watch, but does have some buttons named similarly to the 1440.  Go to the Time and Date section.  The key was to hold down the SET button till the seconds flashes, then use START/SPLIT to adjust the value and MODE to toggle to the next field etc.
Best of luck
Top Timex Watches Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Paul Bade
Are you a Timex Watch Expert? Answer questions, earn points and help others
