Maytag MDB5100A Dishwasher Logo
Posted on Jul 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not draining. fills, then smells Maytag quiet series, 100
Anonymous
Level 3:
Master:
  • Master 383 Answers
  • Posted on Jul 22, 2010
Anonymous
Master
Level 3:
Master:
Answers
383
Questions
Helped
80881
Points
1103
There is clog in your main drainage line, you are smelling the decay of your food, rinse off your dishes before placing them in the dishwasher
Maytag bravos quiet series 300 washer fills and drains. Skips the wash and rinse cycles
Probably a control board issue. Make sure drain hose isn’t too far into drain pipe creating a siphon effect.
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Maytag quiet series 100 stopped midcycle, smells a little bit of smoke
sounds like a burned belt, once the belt is burned from being loose, the burnt spot gets hard and the pulley will not catch to make the machine run , replace the belt.
1helpful
2answers
Foul smell coming from Maytag Quiet Series 300
Hello jscott,
It is typical nowdays for most dishwashers not to drain all water out of the bottom tub (Even where you cant see) due to siphon design and energy efficiency. Try using about a liter of vinegar and throw it on the bottom tub of the dishwasher. Let it run through a full cycle and see how that works. Has worked for me
Sep 07, 2009 • Dishwashers
Burned belt?
Yes, smell like your belt.. if there is water in tub, try to get it out... (wet vac)... slide your washer out and tilt it back so you can see under... there should be 2 belts.. 1 for gear and 1 for water drain pump... and you can check Sears.com for parts.. good luck...
1helpful
Water does not drain completely, mostly but not completely and just stays there Maytag Quiet Series 100
If the machine has a auto sensor or auto clean cycle it is supposed to keep water in the bottom. The sensor has to stay wet for it to work properly. My Maytag drains, then fills slightly to do this.
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
