Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Error Message: load the correct paper cassette: A4
If I want to print a multiple page document, it will only print the first page then stop and the red error light flashes. The error mesage says: "load the correct paper cassette: A4"-- but the paper is already loaded. The screen also says "resume: ok"; "cancel: sys.monitor". When I press "ok" it prints the first page again then error flashes. Each time I press okay, the 1st page prints and nothing else. Any advice is much appreciated. Thanks.
Posted by jaminpage on
Canon tech CROATIA
  • 1,219 Answers
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Posted on Jul 22, 2010
Carl Wiehe
    New Friend:
  • 153 Answers
If it's a e mail your trying to print from a foreign country chance are you just need to delete from print que. Start over it will continue to lock the que until removed. There are incidences of settings of your drawer or cassettes causing the A4 message. A4 is European size. If you force it to print you won't get the full print on the page
. Blank edges. Check your units paper and your print settings.
Posted on Dec 10, 2014
WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A CANON MF3240 . WHAT DOES THIS MEAN? THANK YOU
I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
Jan 18, 2010 | Canon Office Equipment & Supplies
Hi I have a Konica Minolta 2490MF and when I try to print a document/s it will print the first page only then comes up with an error 'incorrect paper size (1LT)' the paper size is correct (A4) and the...
Mr Stephen You have to check paper settings at 3 places first that you are putting correct paper size in correct tray and the paper supporter is touching the paper. Secondly your documents page setup paper size. Finally go to printer properties and under paper selection you will find letter size change it to a4 Thankyou for using free solutions at yafix-ratings from your side would be appriciated.
Jun 22, 2009 | Konica Minolta magicolor 2490MF Laser...
CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same [email protected] of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
Dec 06, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
I had the same [email protected] of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Dec 01, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
I can only receive one page each time
Make sure that the paper size set on the machine matches the paper that you have in the cassette. Also make sure that the sender is not sending legal-size documents if you are using standard size paper.
Is the machine giving any type of error message or code when the error light comes on?
May 15, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
When I try to print to my laser printer MF4150, it prints one copy and the error light comes on and ithas LOAD CORRECT PAPER CASSETTE :A4 I pulled the paper out and reloaded. I Looked in my BASIC GUIDE...
Go in (win xp)
control panel
printers and fax
right click on the printer giving problems
click on properties (down the list)
click on printing preferences
on page size, switch from A4 to letter
click OK
Have a nice day
May 01, 2008 | Olympus P-11 Thermal Photo Printer
Canon MF3240 printer error message.........
I think I solved my printer problem: Chang the paper size to LTR in the printer panel. then go to compter printer setup and choose printing preferences and choose page setup and chang the paper size to Letter (LTR) also. hope this is helpful.
Nov 13, 2007 | Office Equipment & Supplies
I had same thing happen after a fresh Windows install. It was hard to figure out since it had been working fine until then, but luckily it is simple to fix. Open the Start Menu > Settings > Printers and Faxes folder. Then right-click on the Canon MF4100 Series printer and choose Printing Preferences. In there, change the Paper Size to Letter (instead of A4). You may also have to do this in the Print setup for whatever program you're using to print.
Sep 11, 2007 | Canon i-SENSYS MF4140 All-In-One Laser...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
3,638 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
