My friend has an Infinity Reference 1300a car amp. It won't turn off when you turn the car or head unit off. We even disconnected the remote wire, but the amp stays on and will drain his battery. The protect light will go on for a short time, then off... then repeats... The amp works great otherwise. Any suggestions?
The possible area is definitely in the stanby switching circuit. A damage to the relay drive has made the power to be continuously on without the remote switch. You can have two solutions, one you can ignore the fault for the time being and connect a second relay fromt the system to trigger the relay and subsequently switch the amplifier main power. Or you must open the set and look in the remote switching area for a jammed relay, a faulty transistor drive or activation of the bias to the relay drive by a faulty component. Check this out with a good multimeter and you will solve the issue. I hope my advice helps. Good day
