Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Husqvarna YTH2348 hydrostatic transmission slipping
My husqvarna yth2348 hydorstatic transmission seems to be slipping. Is there an adjustment or something i can do?
Posted by rdm6633 on
John Boardwine
    New Friend:
Check your tensioning bracket, when parked and engine off, lower the deck, look underneath from the left hand brake pedal side and work the brake pedal by hand take notice of the bracket with two pulleys mounted on it that move with the brake pedal being pressed and depressed, if you have vertical? up and down movement opposed to horizontal fwd and back movement your bracket mount and or bushing could be worn out.. Mine was, and after replacement it was like the day I bought it new.
Hope you his helps..
Posted on May 08, 2017
5 Related Answers
Anonymous
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
panilling9
panilling9
  • 284 Answers
SOURCE: Where is the oil filter located on the Husqvarna
if its a 23 hp briggs and stratton it should be on the opposite side from the dipstick where you check the oil down low.
It may be black with a briggs and stratton label or it may be yellow with the same.
Posted on Jun 05, 2009
Anonymous
  • 11 Answers
SOURCE: just purchased Husqvarna YTH2348 Purged
As for whining sound I believe this normal. The purging instruction using the bypass valve ingaged on low engine running. Next with the bypass disengaged followed by the fwd with fast breaking and or rev with fast breaking actions to get the wheels to turning and getting better responce takes time. This does take some time to do - in my case 15 minutes or more. My tractor had 65 hours on it before it showed signs of not pulling a slight hill. I had to remove the transaxle and put in 50 wt. motor oil and with the purging I was able to bring new life back to this tractor. The original 30wt. motor oil is fine for a brake in oil and I did drain it and took the bottom cover pan off and cleaned the metal particals on the magnets and cleaned the filter. These transaxle are sealed but have a vent plug at the top of the case. That little plug is hard to get off with out damaging it. My tractor whins in forward and reverse but has good hydrostatic power now. So I say the whin is good!
Posted on Aug 03, 2009
NOT ME
  • 2841 Answers
SOURCE: Husqvarna YTH2348 drive belt slipping
Is there the proper amount of tension on the belt?Look in your owner's manual to find out how to adjust the tension.
Posted on Aug 05, 2009
Anonymous
  • 855 Answers
SOURCE: husqvarna yth2348 keeps blowing fuses as soon as
You have a dead short in the circuit for that fuse. Check for a pinched wire, or a wire rubbed thru a touching metal.
Posted on Sep 28, 2009
Testimonial: "very helpful with the problem"
MOWER WONT MOVE
Drive belt broken or slipped of pulleys, hydrostatic drive filter(s) plugged. Should be one or those, Roger. Follow the drivebelt with your hand (disconnect battery to be safe) and see if it hasn't slipped off the engine drive pulley, idler pulleys, or axle pulley. If you tractor is hydrostat, may be time to replace filter.
Aug 09, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I need a drive belt dagram for a husqvarna yth2348 hydrostatic
Looking at the IPL(exploded parts list) will give you a good look at the route of the belt. Here is a link to use and find your model
http://www.husqvarna.com/us/support/download-manuals/?query=yth2348&types=I&brands=
Apr 20, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Cub Cadet IH 382 Hydro
There is a drain plug on bottom of transmission.I believe it had a 9/16 head I know my Cub Cadet required me to remove the seat to make it easier.
Apr 10, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a model yth2348 mower. How do you adjust the speed of the mower. I have changed the drive belt but it still runs slow.
hydrostatic transmission there is only one throttle setting and that is WFO. if it is running slower than it used to, and the drive belt is snug, then you are looking at a failing transmission.
Sep 19, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Lawn tractor won't go forward or reverse
If the engine is running normally and the drive belt between the engine and the transmission is in good shape, most likely you have a failed hydrostatic transmission.
Sep 05, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Transmission belt slips, can it be adjusted to tighten
You can replace the drive belt, and make sure the springs on the tensioner and clutch pulleys are good, but the belt itself has no adjustment. They stretch a bit with age, also not uncommon for the transmissions to go bad which means slow or no movement even though the engine runs normally.
Aug 10, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
YTH200 TWIN HYDROSTATIC TANSMISSION OVERHEATING
call the manufacture for warrenty work if this is still new
Apr 04, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Hydrostatic drive is weak
Try pulling back on the left foot pedal. This manually adjusts the drive belt tension and is a sign that the engine pulley has worn to the point the belt looses traction. A local repairman told me this last week and mine works fine now although in the very near future I'll need to replace the pully. Good luck
Sep 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Aug 02, 2009 | Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
3,353 people viewed this question
Top Husqvarna Garden Experts
bryan st
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
