Question about Razor MX350 DIRT ROCKET - BLUE
How do i change the rear tier of my razor mx350?
Posted by bradley_umip on
Greg McCarthy
    Genius:
  • 1,340 Answers
I would take it to a shop only because the tire has to be on almost perfect so there is no wobble.They have the proper equipment to make sure it is aligned properly.If you are going to go around 40-50 mph alignment is critical.Even jumping moguls and turning alignment is critical.
Posted on Jul 22, 2010
Razorbase
    New Friend:
  • 11 Answers
The Razor MX350 only does 12 mph. We use 2 tyre irons make sure its empty of air & suggest you leave the wheel in sunlight or in a warm area for a few hours so the rubber is more flexible then ease off inch by inch.
Posted on Jul 06, 2012
Razor MX350 how to reattach kickstand spring
Hi, Jerry for more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Tips for changing kickstand spring Harley Davidson Forums
Removing and Replacing Kick Stand Springs
http://www.marathonandmore.com/mini-moto-dirt-bike-service-manual.pdf
Razor MX350 Dirt Rocket Parts
Razor Dirt Rocket MX350 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 10, 2017 | Razor MX350 DIRT ROCKET - BLUE
Tighten chain
Loosen both rear axle nuts, pull wheel back but keep it straight in the frame. retighten bolts
Sep 10, 2014 | Razor MX350 DIRT ROCKET - BLUE
Razor mx350
Have you tried removing plastic chain guard and making sure chain is not off track i had this problem and that is all it was.
Apr 24, 2014 | Razor MX350 DIRT ROCKET - BLUE
Can you increase the speed on the new 350 razor dirt rocket
MX350 is a 24V bike.
You could change the gearing by replacing the sprockets, or you could replace the electric controller and upgrade to 36V, but you probably would be better off getting a bigger model, like the MX500, as this uses 36V already and the higher voltage allows for higher motor rpm.
Dec 26, 2012 | Razor MX350 DIRT ROCKET - BLUE
Having trouble putting new rear wheel assembly on mx350 dirt rocket
the user manual for the Razor MX350 is available on the web.
here
http://manuals.monsterscooterparts.com/recreational/Razor/
it shows how to remove/install the rear wheel.
Dec 12, 2012 | Razor MX350 DIRT ROCKET - BLUE
Need rear wheel assembly instructions
Please go to:
http://www.razor.com/$assets$/26c3c2bb-d15e-4531-9157-70ec1128fb5b/MX350
Jul 09, 2011 | Razor Dirt Rocket MX350 Miniature Electric...
Razor MX350 DIRT ROCKET - BLUE Logo
528 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
