Nortel Norstar 16-Line PBX Speakerphone Logo
A
Anonymous Posted on Jul 20, 2010
I have A norstar nortel phone that will not ring all other phones in the office ring
Anonymous
Level 1:
New Friend:
  • Contributor 105 Answers
  • Posted on Jul 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
105
Questions
0
Helped
41521
Points
You need to have a technician program your set to ring on incoming calls.
What does dstnct rng mean on nortel phone
Different rings for internal (intercom) vs outside (central-office) calls.
Nortel/Norstar ICS phone system - Calls go to wrong voicemail on calls forwarded with NA
Check the forward no answer setting for number of rings on each extension that has ringing lines. The number of rings should be more than the auto attendant is set to answer with.
3helpful
Nortel Norstar M7208 always reads "Calls For You". What can i do to clear display?
This is Caller ID log
FEATURE 812 View Call Log
FEATURE 813 Manual Call Log
FEATURE 815 Deletes Call Log Items
To have no log see your office administrator or call your local tech to De-program your phone from the system log.
Power source
A Nortel Key Service Unit, an ICS (MICS,CICS), BCM (50,100 etc), Norstar (308,616,824), an Avaya IP Office running Nortel cards, or there is another company that makes a Nortel emulation key system but I can't recall what it is right now.
Carl
Can I change the ring tone for just one of the lines on my nortel norstar phone m7324?
If your phone system has 6.1 software or up then yes,the tech or vendor can program it for you. If you know how to program look under Config/Lines for Ring Type.
3helpful
We have nortel t7316 phones in our office. one
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only
press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
2helpful
T3716 Norstar Phone
If you know how to access admin programming. Yes, all the phones are probably set to "appear only"you need to go into line appearance for all the extensions and make them "appear and ring" If you find it, you can copy that programming from the phone that is already ringing.
Nortel T7316E Voicemail
It sounds like both phones are set to ring on incoming calls and both phones are set to call forward to voice mail box with the same amount of rings . you should turn off the ringing for both phones that way it will not jump between the to mail boxes . now when a call is trans it will go to the box .
Line number rings after disconnect
Make sure DRT is turned off/ set to no and on lines supervised is selected.
Top Nortel Lands Phones Experts
vince
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
