My paper wont feed. Im getting a "no paper fed error" and I cant seem to fix it. I tried reloading the paper, reducing the amount of paper, and cleaning the machine. Please help.
SOURCE: Brother MFC - 7420: Paper will not feed!
Does it make the same sound if you feed the single sheet through the bypass with the paper drawer removed? I hate to say it, but your printer's paper feed mechanism may need replaced. Go to http://www.brother-usa.com/AskUs/default.aspx and ask Brother to diagnose this one; I think they'll confer with me and should be able to point you to a nearby Brother-authorized repair center. Let me know what happens!
SOURCE: automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
SOURCE: my printer, makes a grinding noise, when the paper is feeding through when printinig?
Look to make sure that there isn't a small bit of paper caught in the wheels that push the paper through. Over time, even a small bit in the corner can destroy your printer.
SOURCE: Hi I have a Canon PIXMA
It is fixed, I think. My husband worked on it today and had a look inside the printer with a flashlight. He found a plastic tack had dropped in the rear of the printer, down in the rollers! So he fished it out & we seem to be up & running!
Thank You! Joann Gabriel
