Question about Sony Audio Players & Recorders
My mp3 can be connected to mu pc and play all the music that it's stored there. but when I want to listen using my earphones there is nothing coming out (songs). I just fully charged... what could be the problem.. and the solution.??!!
Posted by oscarpablo on
Anonymous
    Scholar:
  • 41 Answers
1. Check whether the file format of the audio file you are trying to play in the Walkman is supported by the Walkman.
You can check the supported file formats in the manual of the Walkman under "Specifications".
2. Check whether the issue occurs with all the audio files. If you are not able to play the file which you were able to play in past, then it must be the issue with the Walkman.
Then you may reset the Walkman to check whether the issue is resolved.
Press the RESET button located at the bottom of the Walkman to reset it.
You may also try Formatting (USE FORMAT OPTION IN WALKMAN) the Walkman and re-transfer the audio files to the Walkman to check whether the issue is resolved.
NOTE: Never format the Walkman in the Computer as it will delete all the Supporting files in the memory of the Walkman.
You may also try transferring the audio files using the supplied Software like Content Transfer, WMP 11 and SonicStage.
Posted on Jul 21, 2010
Will my RCA TH1814 MP3 play without earphone? And how?
MP3 players do not have built-in speakers and you need earphones to listen to music etc. on these players.
You connect this player to powered speakers to use it without earphones.
Oct 18, 2012 | Audio Players & Recorders
My sakar dicital music palyer voice recorder wont play the music i downloaded onto the file
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Apr 06, 2012 | Audio Players & Recorders
Can we hear to music without an earphone connected??
You need earphones to listen to music and movies.
Most
MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
Click on this link for instruction on converting music files to mp3 file format:-
May 06, 2011 | Transcend T.sonic 850 Digital Media Player
Can we view movies in trancend mp850 and can we hear music in ttrancend 850 withiut earphone
Yes you can view movies BUT the movies files must be converted to a format that can be played on your media player.
Check the specification of your MP3 player to determine thetype of video file format it uses. Most common video files that MP3 players use are, AVI andWMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is anincompatible video file format, then you need to convert that video file to aformat that your MP3 player uses. Click on this link for instructions on converting videofiles for MP3 players :- http://www.fixya.com/support/r5874192-play_videos_mp3_player MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
Click on this link for instruction on converting music files to mp3 file format:- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
May 06, 2011 | Transcend T-Sonic 850 Digital Media...
Can we hear music in trancend 850 without an earphone connected??
Most
Earphones on my turtle beach x1's not working
Try using the headset to listen to your iPod or MP3 player. Plug the USB plug into your Xbox or PC USB port, then plug the X1 green plug into the Headphones jack on your iPod or MP3 player. Make sure the master volume is up on the X1 (inline volume control box). Play a tune on the MP3 player. Do you hear the music? If yes, the X1 is fine. If no, you should contact Turtle Beach tech support and tell them about it.
Jan 09, 2010 | Voyetra Turtle Beach Ear Force X1 Headset
IPod Not Working
Does your iPod come on? If not, your battery could be bad.
If you can see the music playing, but cannot hear anything, you could have a bad earphone jack or a bad circuit board.
You can tell if it is the battery the iPod will not come on at all unless it is attached to the computer or to a power outlet.
If you can move the earphone jack around while playing music and hear something, then it is the headphone jack. If you move the jack around and hear nothing, then I would suspect the circuit board.
If you have a device that can play your music out of the USB port on the iPod, you can make sure that it is the circuit board that way. When the circuit board is bad, music will not play out of the headphone jack or the USB port.
Hope that helps.
Dec 09, 2008 | Apple iPod MA446LL/A MP3 Player
My mp3 doesnt play music properly
This is caused by the ground connection from the earphone socket not making contact with the main PCB.
This can be repaired by anyone competent with a soldering iron.
The four contacts on the earphone socket need to be re-soldered.
Aug 28, 2007 | Philips SA1100 MP3 Player
Sound capabilities
The symptoms you describe are caused by a break in the earphone socket ground connection.
If you are confident enough, dismantle the player and re-solder the 4 connections to the earphone socket.
Oct 04, 2006 | Philips GoGear HDD6330 MP3 Player
176 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
