Most likely it is the drum cleaning blade. One indicator of the drum cleaning blade going bad is that the black lines will get worse as you run multiple copies. So if you make 10 copies for example, the last copy out will be streaked worse than the first copy out. Drum cleanig blades are about $30 bucks plus whatever your local service guy charges for a svc call.
Good Luck and Thank You for using Fixya.
Testimonial: "make sense.. though i have not done anything yet.. as i need an estimate of the likely cost for replacemnet etc.. helpful comment, thanks!"
