Question about Microsoft Windows Vista Business DVD 66J-02289-oem PC Desktop
Citrix XenApp 12.0 Web client install crashes.I get these details: Problem signature: Problem Event Name: APPCRASH Application Name: TrolleyExpress.exe Application Version: 12.0.0.6410 Application Timestamp: 4b987bf1 Fault Module Name: ntdll.dll Fault Module Version: 6.0.6002.18005 Fault Module Timestamp: 49e03821 Exception Code: c0000005 Exception Offset: 00049b6c OS Version: 6.0.6002.2.2.0.256.6 Locale ID: 1033 Additional Information 1: 606f Additional Information 2: d947b8e359029bc23cb47425aaab2131 Additional Information 3: 79e1 Additional Information 4: ed9e307f283b0b8e6fa907f2c5222acc Read our privacy statement: http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409 I'm able to install version 11
Posted by Joseph Murphy on
3 Related Answers
Anonymous
  • 77 Answers
SOURCE: APPCRASH.
Use total uninstaller to uninstall it then reinstall it again
Please VOTE 4 ME for better attention
Posted on Oct 02, 2009
Anonymous
  • 9 Answers
SOURCE: Problem signature: Problem Event
Try this
  1. Go to the Control Panel and click Printers
  2. Right-click on the white space and click "Run as administrator > Server Properties"
  3. Click on the "Drivers" tab, click on the offending printer and click on the "Remove" button.
When prompted, click "Remove driver and driver package."
Answer "Yes" when prompted to delete the driver.
4.You will then see a dialog indicating that driver package information has been collected. Click on the "Delete" button.
5. Back in the printer list, delete the offending printer by clicking on it and pressing the Delete key on your keyboard.
For really stubborn printers that refuse to delete, note the files the printer driver uses and delete them while in safe mode. To do so, on the "Drivers" tab (see above), click the printer and click properties. Sort the "File" column alphabetically by clicking on the heading. Write down the files involved and also write down the "driver path" above the "File" column. Delete these files in safe mode, then repeat the removal procedure above.
OR if problem is due to a corrupted spool queue
Open up c:\windows\system32\spool\PRINTERS
Delete the contents of the directory (not the directory itself).
Retart the print spool service
Posted on Feb 01, 2010
Ali Khan
  • 2291 Answers
SOURCE: Problem Event Name: APPCRASH Application
uninstall it and then reinstall, clean up registry files for that , download reginout registry cleaner to fix problem
Posted on Aug 23, 2010
Problem signature: Problem Event Name: APPCRASH Application Name: integrator.exe Application Version: 12.0.2110.8 Application Timestamp: 4ec65a41 Fault Module Name: MainControls.bpl Fault
If this is causing you to have crashes, the .exe is probably corrupt. It belongs to booster and certain tuneup utility programs ("Dachshund Integrator or TuneUp Utilities (version 2006, 2009) or Glary Utilities (version 3) or Glary Utilities PRO or Auslogics BoostSpeed"). If you have any of these programs installed I'd uninstall it and restart your computer. Then reinstall if you want to use the program still, though preferably after an update. I'd also clean your computer with CCleaner and remove junk files before reinstalling. This will clear corrupted files that might not have been removed with the uninstallation of the program. If you continue to experience this issue, install sandbox and make sure the program runs within sandbox. This will prevent any faults or issues with the program from interfering with your OS.
Sep 07, 2014 | Microsoft Windows Vista Home Premium with...
App Crash is often caused by issues in Windows Registry. To avoid entire system corruption it is recommended that you immediately fix App Crash.
- Scan for Virus and Restore Original Versions of Infected System Files.
- Exclude Concerning Application from DEP and Firewall Protection.
- Fix windows registry with Reginout.(Must)
- Repair App Configurations.
- Uninstall Recent Updates.
Oct 29, 2013 | Microsoft Computers & Internet
MGA BUGO MO !! piste ... KA ! CHE ! pak u
Oct 14, 2013 | Computers & Internet
You could uninstall unzipexpress and install winrar or winzip.
Sep 20, 2013 | Microsoft VISTA Computers & Internet
Windows explorer crashes - APPCRASH
Uninstall IE 9 in the add and remove section and restart the computer, now re-install IE 9, this I hope will resolve your issue.
Jul 04, 2012 | Acer Aspire One PC Notebook
Uninstall and re-install...see if that helps.
Sep 03, 2009 | Acer Aspire 3935-6504 Notebook
Sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe ...
sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe Application Version: 4.3.4.17 Application Timestamp: 44fd31e8 Fault Module Name: ProfileU.exe Fault Module Version: 4.3.4.17 Fault Module Timestamp: 44fd31e8 Exception Code: c0000005 Exception Offset: 00001fda OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: 253c Additional Information 2: 287b034b0bef0590cba0ccef4c4b4b77 Additional Information 3: 7de0 Additional Information 4: bfe79fb32a74e3eb99cc45f1169d5e8b
Aug 07, 2009 | Computers & Internet
Problem Event Name: APPCRASH Application Name: iexplore.exe
I think it is a usual problems, u can try to delete some bad application or spam or anything from : internet explorer - select tools - then internet option - in tab general, choose delete and then checklist all components there - and then OK
if it is doesn't works, you just have to enabled/uninstall your internet explore through program files or registry
hope works,
May 30, 2009 | Microsoft Internet Explorer 7
Open Questions:
KYOCERA PRINTER Customer care Phone nUmber+1800 828 0294 Get easy steps to forgot or change KYOCERA PRINTER customer care rKYOCERA PRINTER via phone number 1800 828 0294 just follow some steps to recover KYOCERA PRINTER customer care while you want. In varoius conditions many people lost their account customer care and much more secure information or information may be hacked by anyone so in that case people want to configure KYOCERA PRINTER with KYOCERA PRINTER or other microsoft account services. Their are many certified officer to suggest people that how to change or rKYOCERA PRINTER KYOCERA PRINTER voicemail customer care using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to rKYOCERA PRINTER KYOCERA PRINTER customer care to rKYOCERA PRINTER or change it quickly, if you have any of them so contact to get well KYOCERA PRINTER care form us. KYOCERA PRINTER customer care rKYOCERA PRINTER not working XEROX PRINTERcustomer care rKYOCERA PRINTER phone number KYOCERA PRINTER customer care rKYOCERA PRINTER contact number KYOCERA PRINTER customer care rKYOCERA PRINTER help KYOCERA PRINTER customer care rKYOCERA PRINTER care KYOCERA PRINTER customer care rKYOCERA PRINTER wont work KYOCERA PRINTER customer care rKYOCERA PRINTER wont work KYOCERA PRINTER customer care rKYOCERA PRINTER link KYOCERA PRINTER customer care rKYOCERA PRINTER issues KYOCERA PRINTER customer care rKYOCERA PRINTER usa KYOCERA PRINTER customer care rKYOCERA PRINTER customer care service. XEROX PRINTERemail account customer care rKYOCERA PRINTER ' free KYOCERA PRINTER email customer care care ' cannot rKYOCERA PRINTER KYOCERA PRINTER email customer care ' KYOCERA PRINTER email customer care care ' KYOCERA PRINTER email customer care care download ' KYOCERA PRINTER email customer care care software ' free KYOCERA PRINTER email customer care care . KYOCERA PRINTER email customer care change, KYOCERA PRINTER email hacked customer care changed, KYOCERA PRINTER email hacked can't change customer care, change KYOCERA PRINTER email customer care on iphone, change KYOCERA PRINTER email customer care on ipad, change KYOCERA PRINTER email customer care on android, KYOCERA PRINTER email account hacked can't change customer care, how to change KYOCERA PRINTER email customer care on droid, KYOCERA PRINTER email customer care problems, KYOCERA PRINTER email customer care not working, KYOCERA PRINTER email account customer care rKYOCERA PRINTER.
Apr 04, 2019 | Microsoft Computers & Internet
Microsoft Windows Vista Business DVD 66J-02289-oem PC Desktop Logo
1,203 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
