Question about Gigabyte GA-7DX Motherboard
Onboard sound is not working. The setup program for AC97 Sound drivers advises that the BIOS setting is disabled - but its not! I am not sure if there is a jumper on the motherboard to enable disable onboard sound. The motherboard is a GigaByte GA-7DX+ running an AMD Athlon processor.
Posted by bfmurphy on
Anonymous
    Brigadier General:
  • 10,406 Answers
Restart your computer.
Enter BIOS-setup mode.
Navigate through the menus to "enable" the onboard audio.
Posted on Jul 22, 2010
Would please tell me step by step how to log into the Bios and make sure my onboard sound is enabled might say onboard AC97?
Reboot the computer and watch the screen for which key it says to hit to get into the Bios or System Setup and when you see the message, hit the key. Look thru the bios to see if it has settings for the sound.
Make sure you have the sound volume turned up and not on mute in the Audio Sound properties. Click Start/Control Panel and look for Audio or Sound to check the volume and make sure it is not on mute.
You can also get into the Audio Properties by clicking on the megaphone at the bottom right near the time.
You can try downloading the Audio Drivers.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Audio drivers.
You can also download AC97 drivers from Driver Guide at:
http://www.driverguide.com
Try the VLC Player. It has drivers and codec. I've seen it solve many sound problems.
Try using VLC as your player. Go to www.google.com and in the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Download and install it. It downloads and installs in 3 minutes or so. It's a very fast player, smooth and it can play just about any type of dvd formats and media. It's totally FREE.
1helpful
Replacing a defunct AC97 Audio devise card with PCI sound card. Told to disable onboard audio with jumper. cannot find manual to locate JP7 devise looking for mainboard manual.
The manual can be found here.
Normally, the onboard audio is disabled through the BIOS settings.
Check your "integrated Peripherals" tab in the BIOS for your on-board audio device settings.
I did not see anything about JP7 when I skimmed the maual.
1helpful
2answers
Audio drivers for vista ??
I don't think ASUSTek support the Vista drivers for K8V-MX at their website.
It might be best to disable the onboard sound through BIOS selection and use an external PCI sound card with Vista support.
Where are the audio jumper on board of ms9158e+, i want to disable sound. my new audio card clashes with on board audio.
It probably is *NOT* a "jumper" setting on the motherboard.
Instead, restart the computer, and press DELETE to enter BIOS SETUP MODE.
Navigate through the menus, and you should find some "enable/disable" setting for the "OnBoard AC97 Sound". Disable, and "save settings", and let the computer reboot.
1helpful
2answers
Where is the jumper to disable onboard sound on
there are no jumpers to disable the onboard sound you need to enter the bios setup by pressing del as soon as you power up the system once in the bios setup page look for the integrated peripherils and enter that menu then look for via onchip pci device and enter that submenu there you should find the setting for the audio and it will be set to auto or on then you just have to change it to off or disable .Hope this helps
K9mm-v (msi 7312) no sound even with drivers installed
Make sure that the drivers you are downloading are for the correct operating system
How to unsinstall my onboard sound card drivers
You can usually disable your onboard sound card by going into your BIOS setup when your PC starts. Older mother boards have a jumper setting on the board to disable onboard sound. If you cannot do either of these, then just disable your onboard card in "device manager"
Best wishes,
Graemevm
2helpful
2answers
No audio device detected
hi not sure what is the full model name for your m/board but you can try to reinstall the sound driver again using the correct driver from the orginal manufacturer foxconn.. you can get the driver from below link...
http://etech.maiila.com/foxconn-rc4107ma-drivers-and-specification
hope this helps...
good luck
Sound drivre
Do you have onboard audio or a sound-card?
If you are using onboard audio try checking the motherboard's BIOS to ensure that the audio was not disabled. To enter the BIOS watch the screen VERY closely during the startup procedure. Typically the computer will mention something to the effect of, "Press F1 to enter Setup." You are looking for a similar message listing the key to press to enter, "setup." You will have to repeatedly press that key until you enter the BIOS screen. As a hint, if you see the Windows loading screen, you missed the screen notifying you of the key associated with entering setup.
Once you manage to enter the system BIOS, use your keyboard's arrow keys to select different menu options. Using the ENTER button on your keyboard enter some of the menus looking for options on onboard audio or integrated sound. Once you do find such an option check to see if it is disabled or enabled. If you're using onboard audio, you will want to ensure that it is enabled in the BIOS. Once you changed the settings exit the BIOS saving changes.
WARNING: Only change this particular setting! If you do not know what you're doing with the other settings you could potenitally damage or destroy your computer!
If the audio was never disabled in the BIOS and assuming you're using Windows, check your audio controls. To check these settings go to the control panel and open the Sounds and Multimedia (or Sounds, Speech, and Audio Devices. Then Sounds and Audio Devices) application. Afterward click on the, "Volume" (Or Audio) tab at the top. Now click on the, "volume" button associated with the, "Sound Playback" section. Now make sure your main audio mix is turned up to your desired level.
If your audio is still not playing try changing the, "Default (Playback) Device" for the, "Sound Playback" section. If you have more than one sound source, you could be using the wrong one. Changing the default playback device might send sound to the audio ports you are currently using thus enabling your sound.
If it's still not working post a comment telling us what methods you tried which failed. I'm sure we can get your sound working. :-)
2answers
NO Audio even after putting in own sound card
Difficult to diagnose from afar but go to Start>Run, then type 'dxdiag' without quotes and see if; when it does a sound and video test anything shows up.
Gigabyte GA-7DX Motherboard Logo
Top Gigabyte Computers & Internet Experts
Ekse
Chris May
Chris May
Michael Thomas
Michael Thomas
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
