Question about HP LaserJet 4730 MFP Printer
How do i scan images using the hp 4730 mfp
How do i scan images using the hp colour laserjet 4730 mfp
Posted by ma4indesigns on
Anonymous
    Problem Solver:
  • 11 Answers
Check under general reference (link below). it should mention how to fax, e:mail and copy. if you copy to file / pc that should work as the scanner.
otherwise make sure the "scanner" facility is installed as some MFP's do not come with all facilities installed. (and therefore may not give the option on the screen.)
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=468688
Posted on Jul 21, 2010
HP Laserjet m5035 blue line when colour scanning to email
Try checking for debris or other on the ADF itself and below on the prism. The ADF cover glass could be spotless, but if there is a speck on the prism itself, this could cause the actual prism to send a line while scanning.
Dec 30, 2013 | HP LaserJet M5035 MFP Printer
Laserjet m5035 line when colour scanning
Check to see if not only the ADF is spotless, but the prism below it. If there is something stuck there you could see it.
HP Color Laserjet 4730 MFP scanner not initializing
open the scanner's glass cover ,,, there is a white sensor on the backside of the glass ,,, clean it with a little wet fabric ,,, then change the scanner unit's place to be exactly under the sensor ,,, close the cover ,,, turn on the power ,,, and give me a good rate ,,, :)
Sep 22, 2013 | Office Equipment & Supplies
My computer is not communicating with my printer
Try reinstalling the printer driver.
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Mar 27, 2013 | HP LaserJet 4730 MFP Printer
Hp 4730 fuser reset
Anyone with information on how to reset the Fuser page count without chanigng the fuser on HP 4730 MFP? The fuser in the unit is in very good condition and replacements are not cheap. Any help would be much appreciated.
Mar 12, 2012 | HP LaserJet 4730 MFP Printer
How to scan to computer using hp laserjet m3035xs mfp connect using a USB CABLE
install the scanner software on your cd hp and then in Word go "insert+image+scanner"
Jun 22, 2011 | HP LaserJet M3035 MFP Printer
When sending print jobs to the HP MFP 4730 device keep processing job and data led keep blinking with no printing
this problem comes due to formatter card it is faulty replacur problem will be resolvee them it will work ...........
Jun 17, 2010 | HP LaserJet 4730 MFP Printer
Incoming faxes on the laserjet 4730 mfp look like bar-codes. Other print jobs are OK
Unexpected image like barcode as shown below can occur when using the automatic document feeder (ADF). You are using the ADF for incoming faxes. So the problem occurs.
If the copy does not look at all like the original document, make sure that no media is on the flatbed glass from a previous copy job.
I hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 26, 2010 | HP LaserJet 4730 MFP Printer
HP Color LaserJet CM1017 MFP - won't scan
Please try installing software components for your MFP device.
Feb 12, 2009 | HP LaserJet CM1017 MFP All-In-One Color...
HP LaserJet 4730 MFP Printer Logo
707 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
