Question about JUMP START SYSTEM
I have a power on board veco12pob 450 amp jump starter unit and my question is what kind of adaptor do i need . I would like to know the volts and amps.
BelchFire
    Problem Solver:
  • 5 Answers
I have the same problem: today I tried a 12 volt, 1500 milliamp (1.5 amp) power cord and it has charged mine halfway, so far. It fits the plug in, but not certain, yet, that it has enough power to fully charge.
Posted on Aug 28, 2010
obiwankoebbe
    Problem Solver:
  • 5 Answers
Http://servicenet.blackanddecker.com/Products/Detail?productNumber=VEC012POB
Posted on Feb 01, 2011
Battery state light stays on & discharges battery
something not right here with the question/request---""unplugging the 230 volt charger"????--I don't know of a 230 volt charger---unless this is in Europe---a 120 volt charger---in USA-- but I'll try this---a LED light does not use enough electricity to discharge a battery over night--- do you have another function on this unit such as a compressor or lights--something that maybe on???---another thought is that the battery has failed causing this malfunction----has this been wet/underwater---a malfunction with a diode in the electronics may cause the charger to try and charge the battery via ac and cook the battery as well as the circuit board---this is a real issue here---I'm not getting enough info to give an intelligent answer---i need to know if anything has happen what has happened before and up to this point when this issue started---I don't know what happens if when using these units if you connect to (jump start) battery with reverse polarity--if it bows a fuse or cooks the unit---sorry I can't be more helpful
Feb 14, 2015 | 450 Amp Battery Jump-Starter
A power on board veco12pob 450 amp jump starter, but not charger
Have you check for a blown out fuse? You may not be getting enough amps to charge the unit
Oct 02, 2014 | Vehicle Parts & Accessories
I need to know how to recharge my 450 amp jump starter
There is a charging port on the front of the unit next to the LED work light.
The wall charger it came with, is a 12VDC 500ma.
Positive center coaxial connector.
Radio shack usually can match the unit if you bring it in to them.
My charger was pouch Velcro-ed to the unit.
Kings Model KU3B-120-0500D
Jan 27, 2014 | PEAK PKC0BJ 450 Amp Jump-Starter USB Power...
I have a veco12pob power on board system 450 amp. I need a 12 volt power supply. how do I get one?
Look at the connection hole for the charging; they sell universal chargers everywhere (frys best buy online). These chargers come with a variety of sizes. Match it up and you're done
Nov 24, 2013 | JUMP START SYSTEM
I need a 110/120 volt ac/dc adapter power cord for recharging from standard wall socket. For a Peak 450 jump starter
After searching the internet for a ph number for Peak power I finally found the web.
http://www.peakauto.com/contact/site.
phone 800-323-5400
If the part department doesn't have the answer ask to be switched to tech support.
They were able to provide me with the part numbers I need for new wall supply cord and an DC adapter for the car.
My jump starter is no longer made...
Nov 15, 2013 | Peak Performance Peak PKC0BL 450 Amp Jump...
Need to find power adapter for my veco12pob,i know i need a 12 volts one.but how many amps does it has to be?
http://www.baccusglobal.com/bd/manuals/NEW%20MANUALS%20FOR%20WEB/VEC012POB%20MANUAL.pdf
Apr 25, 2011 | JUMP START SYSTEM
Air compressor is working but air is not pumping to the tire. Initially, started filling but after certain time, pressure in the tire stopped increasing
Checkthis website:
http://servicenet.blackanddecker.com/Products/Detail?productNumber=VEC012POB
The PN is Vec012POB not Veco12POB
Jan 31, 2011 | Peak Performance Peak PKC0BL 450 Amp Jump...
I have a veco12pob power on board system 450 amp. i need a power cord. how can i get one.
I NEED A POWER SUPPLY AC ADAPTER FOR VECO12POB BATTERY JUMP START SYSTEM.
Nov 27, 2010 | JUMP START SYSTEM
JUMP START SYSTEM Logo
4,273 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Sheldon Dedek
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
