Hi, the points gap is 14 to 16 Thou. Inlet valves 4 thou, exhaust valves 6 thou. I dont know the settings in metric, so using a set of imperial feeler gauges, that measure in thousands of an inch.
An easy tip for setting the points, is use the thickness of a standard cardboard, Business Card, it is the correct thickness for your points gap.
Testimonial: "Thanks.. when ya can't find what you need after spending hours on the net..this is the place to go."
Try to keep the point gap at .014".. this can effect the timing.
.004" = .1mm
.006" = .15mm
Set valves on cold engine!
