Fedders A6P09S2A Air Conditioner Logo
Posted on Jul 21, 2010
Reset button Cannot restart air conditioner after I pressed the reset button. What can I do?
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Jul 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
3807
Points
15
Unplug it for a few minutes and see if this resets the unit and cures the problem. If the unit was running when you did this, you cut power to the compressor and it will lock out for awhile until pressures equalise. This is normal and is meant to protect the compressor from being short cycled.
2answers
Arctic King 10k Wac Rmt unit is beeping
To reset your arctic king air conditioner, you will first have to locate the reset button. This button is typically located by the power cord. Press and hold the reset button for around 3 to 5 seconds, then release it to restart your air conditioner. The Arctic King AC unit will need around 10 minutes to complete the reset, then you can check if restarting your AC solved the problem.
https://www.luceaircon.sg/blog-article/arctic-king-air-conditioner-troubleshooting-guide#stronghow-to-reset-your-arctic-king-air-conditionerstrong
Best to you.
tip
How to Reset Your Air Conditioner Filter Light
<span style="font-weight: bold;">Cabin Air Conditioner:</span><br /> <ol> <li>Press and hold down the Off button for 4 seconds.</li></ol><span style="font-weight: bold;">Carrier Air Conditioner:</span><br /> <ol> <li>Press the Reset Filter button to reset the timer that calculates the next air filter change after you have inspected / cleaned the indoor return air filter.</li></ol><span style="font-weight: bold;">Daikan Air Conditioner:</span><br /> <ol> <li>Press the Filter Clean Reset button to reset the CLEAN FILTER INDICATOR after you have inspected / cleaned the indoor return air filter.</li></ol><span style="font-weight: bold;">Frigidaire Air Conditioner:</span><br /> <ol> <li>To reset after cleaning the filter, press the "Filter Reset" button and the light will go off.</li></ol><span style="font-weight: bold;">GE Air Conditioner:</span><br /> <ol> <li>Turn the air conditioner OFF and unplug it.</li> <li>The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter.</li> <li>After cleaning, replace the filter and plug the air conditioner back in.</li></ol><span style="font-weight: bold;">Honeywell Air Conditioner:</span> <ol> <li>Press and hold the i button until the timer is displayed, followed by pressing the Up Arrow button (next to the Wake button)</li> <li>Press the Run Program button.</li></ol><span style="font-weight: bold;">Kenmore Air Conditioner:</span><br /> <ol> <li>To reset the filter indicator, press and hold the filter reset button for 3 seconds.</li></ol><span style="font-weight: bold;">Lexus Air Conditioner:</span><br /> <ol> <li>Without having foot on the brake, press the Start button twice to get to the IG-ON position.</li> <li>Then press and hold the "hard" OFF button next to the "hard" Auto button. Hold the OFF button for approx 5 seconds and you hear several beeps.</li></ol>or<br /> <ol> <li>Turn the engine switch to IG-ON mode.</li> <li>Push and hold the A/C OFF button for more than 4 seconds.</li></ol><span style="font-weight: bold;">Lexus 2008 Air Conditioner:</span> <ol> <li>Push the "INFO" button & touch "Maintenance".</li> <li>Touch the desired button Delete All: To cancel all conditions which have been input or Reset All: To reset the item which has satisfied a condition. If "ON" is selected, the system gives maintenance information with the "Information" screen when the system is turned on. If "OFF" is selected, the "Information" screen is disabled.</li> <li>Input the Notice of Date: The next maintenance date must be input.</li> <li>Now input the Notice of Distance: The driving distance until the next maintenance check.</li> <li>Delete: To cancel the date and distance conditions.</li> <li>Reset: To reset the date and distance conditions.</li> <li>Touch "OK" The screen returns to the "Maintenance screen.</li></ol><span style="font-weight: bold;">Lincoln LS 2001 Air Conditioner:</span><br /> <ol> <li>Press and hold the setup button above the radio until it says system check. NOTE: All the doors must be closed.</li> <li>Watch the system check when it goes to A/C filter hit the reset button.</li> <li>Hold down the reset button to confirm.</li></ol><span style="font-weight: bold;">Lincoln LS 2003 Air Conditioner:</span><br /> <ol> <li>Press the STATUS control to access the System Check function, the message center will display A/C FILTER XX% RESET FOR NEW.</li> <li>Press and hold the RESET control to set to 100%.</li></ol><span style="font-weight: bold;">Lincoln LS 2005 Air Conditioner:</span><br /> <ol> <li>Insert the key and turn the ignition to "Run" or "On." It is not necessary to start the engine.</li> <li>Press the "Status" button above the radio until the system display changes to "AC Filter."</li> <li>Press and hold "Reset" above the radio. The system will beep and the "AC Filter" display resets to "100%."</li></ol><span style="font-weight: bold;">Maytag Air Conditioner:</span><br /> <ol> <li>Press the "Fan" button 2 times, then press the "Mode" button 1 time and it will reset.</li></ol><span style="font-weight: bold;">Whirlpool Air Conditioner:</span><br /> <ol> <li>Push in the filter reset on the remote using a straightened out paper clip or similar.</li></ol>or<br /> <ol> <li>On the control panel, press and hold the Mode and the Up Temp Arrow buttons for 6 seconds.</li></ol>or<br /> <ol> <li>After having cleaned the filter just press the reset button located on the indoor unit behind the front panel to interrupt the flashing of the filter monitor indicator.</li></ol>
on Jun 17, 2011 • Heating & Cooling
How do I restart my Rheem 13AJN48A01 outside unit ?
1) Raise the temperature on your thermostat to 80-degrees Fahrenheit. This prevents the unit from turning on while you are resetting the compressor.
2) Find the red rubber boot that covers the rest button on the back of the air conditioner case. The reset button is near the copper lines at the bottom of the case.
3) Press the reset button once with your finger. Set the thermostat to the desired temperature. This usually restarts the Rheem air conditioner. If this does not work, call a Rheem professional to service the unit. Power surges sometimes destroys capacitors in the unit requiring a professional to replace.
2answers
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
My fan speeds on my frigidaire window unit keep changing by itself. Input and advice please!!!
Hello Jordan, thank you for your inquiry!
From my understanding the fan speeds on your Frigidaire air conditioner changes on its own. Do you own a remote with your air conditioner? It could be getting accidentally pressed and that is causing your fan to switch. If you do not have a remote with your air conditioner it could be a potential issue within your control panel or keypad. I would then recommend performing a reset on your air conditioner and you can do that by unplugging the power cord and pressing the reset button. Once the reset button has been pressed you would need to hit the test button and then you should be able to plug it back in. If this does not resolve your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Where is the button to reset on a frigidaire air conditioner
Hi friend, that's a great question!
To reset your Frigidaire air conditioner you would need to make sure the appliance is turned off and unplugged. On the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in and it should be reset. -Matt
How do i fix E1 error
  • Press the "Power" button to turn off your unit and then remove the filter from the filter panel on the side or front of your air conditioner. Refer to your manual if you are unsure where the filter on your unit is located.
  • 2 Inspect the filter. If it is dirty, brush off dirt, debris and lint. If it is really dirty, wash it with mild soap and water and allow it to dry completely. Reinsert it into its compartment. If your filter is worn out or damaged, purchase a replacement filter from an appliance or hardware store and replace the old one.Turn on the air conditioner. Move to the next step if the LCD continues to display the E1 error code.
  • 3 Check for a reset button on your air conditioner and press it to reset your unit. Some of the newer air conditioners have reset buttons to restore the default factory settings. Press the "Power" button on the front panel of your air conditioner to power down your unit if it does not have a reset button. Unplug the unit from the electrical outlet. Leave the air conditioner off for several hours to see if it will reset.
  • 4 Plug your air conditioner back into the electrical outlet and turn it on. If your air conditioner is still displaying the E1 error code, turn it off and contact a qualified technician because the room thermistor responsible for detecting room temperature may be defective.
  • 0helpful
    My Air Conditioner started blowing hot air. Code p2181 came up. I have had problems with my fuse box over my battery. Could this be the problem again?
  • 2
    Inspect the filter. If it is dirty, brush off dirt, debris and lint. If it is really dirty, wash it with mild soap and water and allow it to dry completely. Reinsert it into its compartment. If your filter is worn out or damaged, purchase a replacement filter from an appliance or hardware store and replace the old one.Turn on the air conditiner
  • Check for a reset button on your air conditioner and press it to reset your unit. Some of the newer air conditioners have reset buttons to restore the default factory settings. Press the "Power" button on the front panel of your air conditioner to power down your unit if it does not have a reset button. Unplug the unit from the electrical outlet. Leave the air conditioner off for several hours to see if it will reset.
  • 4
    Plug your air conditioner back into the electrical outlet and turn it on. If your air conditioner is still displaying the E1 error code, turn it off and contact a qualified technician because the room thermistor response to detecting room tempeture is needs replacement I say I'd loose business but rather clients trust me then go elsewhere recommend me for what you'll pay get a new one if it doesn't work
  • 0helpful
    How do you re-set error code for "change filter" when filter has been changed on Carrier programmlbe thermostat
    Clean Filter Feature -
    The thermostat will display the CLEAN FILTER indicator when it is time to change the filter. Press the Reset Filter button to restart the timer after the filter has been changed or cleaned. Helpful?
    AFTER PLUGGING UP THE AIR CONDITIONER, IT DOESN'T COME ON.
    Do you mean plugging in the air conditioner? If so first check the plug and see if it has a saftey GFI test and reset button, if it does press the reset button. Go from there.
    Top Fedders Heating & Cooling Experts
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Jay Finke
    Jay Finke
    Mike Cairns
    Mike Cairns
    Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
