Question about Kenmore Elite 45986 Front Load Washer
Front door would'nt open on my kenmore tumble action washer model #417
Posted by dommlo on
blueextc3221
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Repair pump on kenmores tumble action washer model 417 44152400
how do you know it is a pump? I'd
check with these parts suppliers. I believe I used their parts about 5 years ago. They were helpful
http://www.repairclinic.com/RepairHelp/Washing-Machine-Repair/11-6-896091-/Kenmore-Washing-Machine-41744152400-Troubleshooting
Feb 13, 2015 | Washing Machines
The handle has broken off my dryer (Kenmore Supercapacity 3.5 Quiet Tumble Action Wash-Easy-Acces ) and door must be pushed in very hard in order for it to work properly. Where can I get replacement...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Here is another link that gives you options for the different model numbers.
http://www.searspartsdirect.com/partsdirect/part-model/43142?searchedModel=43142&postFilter=true&modelFilter=true&productCategoryId=0153200&brandId=&brandFilter=false&categoryFilter=true
The 43142 number is a Stock Number, not a model number and could relate to any number of Sears products.
By looking at the parts site with the full model number you should be able to find the handle, Sears price and "Manufacturer substitute numbers".
The 417 prefix for these washers means that they are manufactured by Kelvinator (Frigidaire) so you may be able to get parts from an appliance parts store stocking their products.
Nov 11, 2010 | Kenmore 43142 Front Load Washer
We are getting an error code ddo on our wahser?
The DDO error is telling you that the detergent door is open. This error occurs when the detergent door has not latched properly when the unit is started.
There is a sensor that is dependant on a magnet, that is attached to the door, to trip it and send the proper door closed signal to the control oard. If this magnet comes off, or loose the signal will not be sent to the control board, and the error code will be displayed.
Now for the bad news. The magnet is in such a position that a considerable amount of labor is required to replace it.
Unless you are mechanicly inclined and handy with a box of tools I do not recommend that you attempt this repair. It is very involved and is not a DIY repair. It is best to let a tech handle this repair. An approximate price range for this repair is $175.00 to $275.00, or more depending on where you live.
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Jul 27, 2009 | Kenmore 43142 Front Load Washer
Will not spin or drain
take front panel off in the water pump rubber hose feel to see u can feelsomething in side the pump .this will cause the pump to stop/and not spin
May 12, 2009 | Kenmore HE2 Plus Front Load Washer
Door opens on the wrong side
Usually not. If you can you will need a door kit from sears. But in most cases the manufacture does not want to mess with the doors seal, so they dont offer a change.
Jan 24, 2009 | Kenmore 44072 Front Load Washer
No Motor Action / No Tumble or Spin / Kenmore 417 4405240
Yes, I am!!
Jan 05, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore front load tumble action washer
Snaggs, If your model number begins with 417 it could be a couple of issues. Start with the drain pump. Remove the bottom panel and see if the pump is clogged with coins or debris. It will be on the right. Check the pump impeller. Have a bunch of towells handy as you will have a lot of water coming out at you. When you drop the bottom panel you will be able to see if the belt is on in back. If this does not clear up the problem, more than likley it will be in the motor control board. Catriver...post back.
Sep 23, 2006 | Kenmore 43142 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
123 people viewed this question
Michael Thomas
Michael Thomas
Paul Carew
Nicola Conroy
