Question about FUJIFILM A220 Digital Camera
Fuji A220 Camera fell lens was extended and popped off. everything seems to work fine nothing appears broken. How do I pop the lens back on?
Posted by frankb1217 on
Anonymous
    New Friend:
My fuji a220 shutdown when i turn it on while memory card is inside
if the problem in memory card i tried in pc and it works excellently
Posted on Aug 28, 2010
I keep getting a zoom error message. I turn the camera on and off and this still occurs.
First off how long have you owned the camera? Just to confirm it is a Fuji finepix a360. This means most likely it was dropped or banged with the lens extended out. There are a few things you can try and do yourself. If its under a year old it still has a warranty. If not you can still have it repaired by fuji or an independent repair service.
If your camera is still under warranty, the best thing you can do is to take it to the nearest official repair shop and they should fix it for free.
If your camera is out of warranty, or if the manufacturer refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try the following methods to repair it yourself.
First, make sure your camera has fresh batteries and it is in recording mode.
Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
Another method is to tap the padded USB cover part on a hard surface, for example, a desk. Sounds simple, but it works.
Try forcing the camera lens. Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
Please let me know if you need any further assistance.
Thanks,
Lee
Nov 05, 2009 | Fuji FinePix A360 Digital Camera
Camera felled to floor lens tries but cannot retract camera turns on and off fine, error message "lens error, restart camera" it appears that until lens can function properly and error message is resolved...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 29, 2009 | Canon PowerShot A630 Digital Camera
E 18 problem
May 27, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
Lens filter ring fell off !
I have Fuji 3800 camera, the lens ring on the camera fell off. How do I get the 3 screws out of the camera and how do I fix it.
Aug 13, 2008 | Fuji FinePix 3800 Digital Camera
Lcd reads system error
Apparently often related to a lens motor malfunction. My old 4300 just gave this error for the first time today. The lens extended but made a whirring noise before the message popped up. Nothing I tried would fix it - but after I drove home it worked fine again.
I had a similar problem over a year ago after the camera fell out of my backpack (it was in its own bag but not well padded). When I used it the lens stuck and refused to retract, but I don't recall a "System Error" message. After a few tries, the lens went in and it's been fine since, until today.
Make sure there's nothing (dust, dirt) stuck in the lens barrels. Otherwise, just keep turning it on and off and hope it works.
Dec 31, 2007 | Nikon Coolpix 4300 Digital Camera
Lens stuck
Here is how I fixed this problem. I grasped the lens around the base (larger part) like you would if you were going take off a beer bottle cap.
Very gently while sliding my thumb and index finger around the lens, I rocked it back and forth. DO NOT TRY TO TWIST OR PUSH,.....It felt like it "popped" back on track.
My assumption was it was probably hit from the side, and could not retract, once it was rocked back on track, it worked fine. It felt like it loosened a tiny bit as well.
Good luck.
Nov 26, 2007 | Polaroid I533P Digital Camera
Camera fell on floor and lens popped out
http://www.lensbabies.com/index.php?r=GSLBGeneral&gclid=CJSbjPWUrI0CFQqgYgodlz7D1Q chek site you will find diagram
Jul 16, 2007 | Olympus C-3000 Zoom Digital Camera
FUJIFILM A220 Digital Camera Logo
Top FUJIFILM Cameras Experts
Falling star
Jax Planet
Jax Planet
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
