Question about Syntax-Brillian Olevia 242TFHD 42 in. LCD TV
My Olevia 242TFHD will not turn on. The blue light goes off but the tv does not power on. If I unplug it and plug it back in the blue light will come back on but when I try to power it on it never turns on
  • Syntax Master
  • 8,457 Answers
The tv have a Tuner board problems,this is the board,that take in the broscasting signal cable.Tries unplug,replug about an hour later.The tv should reset it self and work.Not than tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Posted on Jul 20, 2010
6ya staff
SOURCE:
Standby light is on,but my olevia tv will not turn on.
No, someone will need to open set and check voltages etc and also look at power board to see if any puffed up bad caps like these:
Apr 18, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Olevia LCD HDTV 242tfhd will not turn on.
See solution above (from John Adams) if that doesn't work it may be the power board which is available on ebay for $69 incl. shipping. Good luck.
Mar 09, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Olevia tv has no power
Check ur power source?Yes,tries tv unplug,replug back like an hour later,by letting tv resetting itself back to factory setting,see if u get power back?Same problems,than ur tv power supply board is the cause and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power suuply board for the replacement.
Feb 12, 2011 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
I have an Olevia 242tfhd television that just stopped working. The blue light was on and when I pressed it- it wouldn't turn on and the blue light went off. I unplugged it for a day and when I plugged it...
Same happened with my Olevia 540-B11. You can probably find the details of how to disassemble the TV somewhere online. The problem is poor stress-relief on the cables that plug into the secondary (low voltage) side of the power circuit board (PCB). Once the back is removed you'll find the PCB on the left side with three cables connected to the very top of the board. These cables plug into four clips, 3 horizontal clips side-by-side at the top and one vertical clip on the left side. Unplug these cables, remove the PCB and re-solder the sockets (there are approximately 40 solder points on the back of the board). Reassemble your TV and it'll work just fine.
Dec 15, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
My blue powerlight isnt working on my olevia tv it is 3years ol what could it be
If the tv is infact turning on eventhough the power light isnt, its the bulb for the powerlight itself
Nov 20, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Olevia 42 inch Flat Panel has power supply issue... Blue light does not come on and tv does not turn on... I have tried all different things to get tv to work with no positive results
What did you try so far? The main power supply MUST have at least the 5V standby supply section working. This 5v is used by the main control board to send out the command to turn on the main power supply section which will power up the rest of the TV circuits when the power switch is activated either by the power button of remote or on the TV powern button. Look for this 5v first.
Nov 04, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Olevia Lt32hve set won't come on, blue light is on
make sure your tv is on the right input. Some lcd tvs will lose power and default to digital tv input instead of the analog input or composite input used for cable/satellite receivers or even dvd players
Aug 15, 2009 | Televison & Video
Syntax-Brillian Olevia 242TFHD 42 in. LCD TV Logo
997 people viewed this question
Top Syntax Televison & Video Experts
Ekse
Joaquim Martins
Wbix
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
